Engine stalling when cold
OldRedEyes Oct 18, 2012
  1. OldRedEyes
    OldRedEyes Member
    445
    The wifes motor has been playing up the last few days.
    When it's warm it starts and runs fine, but when it's cold i.e. first thing in the morning or after work and trying to go home.
    It turns over fine, starts then the revs just drop off. It will keep doing this until you get fed up and keep your foot on the gas.
    It's as if you need to pull the choke out (That takes me back).
    Any idea's?
    It's a 1.8T by the way
  2. i_786_i
    i_786_i Member
    60
    Sounds like its fuel related. Had a similar issue like this on a bmw - changed the fuel filter and all was well again.
    Try checking the fuel lines, sensor and filter etc otherwise a diagnostic check should hopefully throw out a code.
  3. Bradderz_1988
    3,958
    238
    Could be an immo problem mine used to do something similar where it would start then immediatly die. Have you got access to vagcom ?? A scan may pick something up.
  4. aragorn
    18,444
    847
    Vagcom scan is a good plan.
  5. OldRedEyes
    OldRedEyes Member
    445
    Rather embarasing this tbh.
    Wife looked on the net, said it's the coolant temp sensor, i said i wanted to get it scanned so she should buy me the lead.
    She sent me off to pick up the part from Audi, i fitted it and it has been fine since, saturday morning.
    She still has not ordered the lead!
    She is still gloating!
    Cheers guys
