hi mate the most likely cause of squeeks on a cold engine is one of the belt tensioners . i had this on mine so i changed the alternator one way pulley that never worked but it turned out to be the auxhilary belt tensioner bearing changed this and the sqeek went away
just spray a tiny bit of wd40 on the belts if the squek goes away replace belt and maybe tensioner, thats if it is the problem, but that would be the first thing to look at
i dont know the costs for your model . but for my 1.9 tdi the alternator one way pulley was £34.00 and the auxhilary belt tensioner was £ 36.00 from GSF i fitted them myself if you are taking it to a garage i would have them fit both at the same time
