Need some advice on removing a 1.8 ADR engine.
So far stripped down the front-end of the car and I'm at the point of wondering if it's worth removing inlet manifold, water pump, PAS pump etc, or would it be easier to do all that once the engine is out?
Also I'm leaving the gearbox attached to the engine, so i should just have to undo the engine mounts & gear box mounts, gear box linkages, wiring harness, exhaust, & pipes etc.
Is this fully achievable with just and engine lift & axle stands, and is there any tips to make the job easier?
