engine rebuild
tdi-man Feb 18, 2013
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    heads come of today
    water pump had a leak so new one will be going in any way.
    Blocks ok so new rings / shells / etc oil pump
    recon head
    question is when putting together is it ok to use gasket sealant on inlet manifold and turbo manifold as well as the gaskets ?
    thanks
  2. Lewis583
    956
    91
    You shouldn't need to assuming new gaskets are used
  3. NHN
    29,298
    1,701
    Exactly, just use new gaskets all round.
  4. tdi-man
    1,783
    64
    ok cool thought id ask as like a nice seal .
    all new gaskets and seals are to b used .
    thanks
  5. NHN
    29,298
    1,701
    "Be"
  6. tdi-man
    1,783
    64
    thinking of fitting a oil can can any advice ?
  7. NHN
    29,298
    1,701
    Fitting a oil can can, what exactly is that?
  8. tdi-man
    1,783
    64
    oil catch can .
  9. NHN
    29,298
    1,701
    Typo then.
    Yes, advice is, dont vent to air, check Allard.
  10. bigal23
    bigal23 Member
    206
    Why not vent to air? Apart from being illegal
  11. NHN
    29,298
    1,701
    & thats not a good enough reason for you?
  12. autolatry
    autolatry Active Member
    347
    67
  13. tdi-man
    1,783
    64
    The good news is my bottom end is fine
    The Bad news is the head has cracked where the glow plugs come out :(
    and its a C in the part number
  14. autolatry
    347
    67
    Are you doing the work yourself?
  15. tdi-man
    1,783
    64
    no
