Engine "readiness"
bikefright May 10, 2007
  1. bikefright
    bikefright Member
    43
    I have two "failed/incomplete" items listed under engine readiness:
    Oxygen Sensor
    Secondary Air Injection
    What on earth is the second item??
    ******Updated******
    This is the VAG-COM FAult Code output, note I have resolved the last three items (replaced all 6 ignition coils):
    Thursday, 10 May 2007, 11:44:39
    VAG-COM Version: Release 409.1-US
    Control Module Part Number: 8E0 909 559 M
    Component and/or Version: 3.0L V6/5V G 0010
    Software Coding: 0011751
    Work Shop Code: WSC 00411
    4 Faults Found:
    16815 - Warm Up Catalyst: Bank 2: Efficiency Below Threshold
    P0431 - 001 - Upper Limit Exceeded
    16684 - Shareware Version. To Decode all DTCs
    P0300 - 001 - Please Register/Activate - Intermittent
    16690 - Shareware Version. To Decode all DTCs
    P0306 - 001 - Please Register/Activate - Intermittent
    16687 - Cylinder 3 Misfire Detected
    P0303 - 001 - Upper Limit Exceeded - Intermittent
  2. icenutter
    icenutter Member
    596
    A guess: 2nd one could be something to do with AGR.
  3. bikefright
    bikefright Member
    43
    Thanks icenutter - i've updated my post as I'd made some important mistakes in the post, maybe this might help diagnosis. I've added VAG-COM output too.
  4. bikefright
    bikefright Member
    43
    Just found a PDF here, I know it'f for a TT, but the principal is most likely the same:
    http://www.wak-tt.com/guides/sec_air.pdf
    This links my Secondary Air Injection issue with the Warm Up Catalyst.
    I'm going to check all my vacuum hoses at first as the car has just had a sevice at a stealership.......
