Engine question
lenin Jun 16, 2004
  1. lenin
    lenin New Member
    got an Audi 80 sport 2.0 8v 1991 and took off the cambelt cover the other day to find a large mess of black bits of plastic and burnt looking rubber started the engine with the cam belt cover off and noticed that the tentioner was not spinning was wondering if this is ment to spin as it has a mass of congealed burnt black plastic around it
    was wondering if anyone could give me some incite on to this
    is it ment to be spinning and is it regular to have a mass of like black plastic **** all in the cam belt cover
    cheers
    Ian
  2. Gambba
    Gambba Active Member
    1,361
    Sounds like your tensioner pulley has seized and this is now causing the belt to drag across it causing material from the belt to be deposited on the pulley. Obviously the dragging would produce excessive heat leading to further deterioration of the belt.
    The above is not specifically related to your car, but is a general statement.
