Engine problem, Advice please
AGU-TURBO Apr 7, 2012
  1. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    i drove down to see my uncle a couple of weeks ago and my car felt like it had no power. it was boosting 1 bar no problem but it was like sombody was turning a top off for the petrol lol. anyway the next day i cleaned my maf and did a full service inc spark plugs and ive been driving it all week but only about 10 mile a day no problem but i went over to see my uncle again last night and it started doing the same thing again. my uncle lives 25 mile away so only seems to do it on longer journeys. Ive also noticed it doesnt start up in a morning very well either. Ive pluged it into vag com and have this fault code:
    1 Fault Found:
    00561 - Mixture Adaptation
    14-00 - Adaptation Limit (Add) Exceeded
    Any help most apreciated
  2. <tuffty/>
    21,950
    4,227
    00561 - Ross-Tech Wiki
    00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
    Possible Symptoms
    Engine Jolting
    Increased Fuel Consumption
    Poor Idling/Jolting
    Reduced Boost Pressure
    Possible Causes
    Mass Air Flow Sensor (G70) faulty
    Fuel Pressure too Low
    Leaks in Intake Air System and/or Exhaust System
    Injector(s) faulty (i.e. coked)
    Possible Solutions
    Refuel Vehicle
    Check Fuel System Pressure
    Check Mass Air Flow Sensor (G70)
    Check Intake Air System and Exhaust System for Leaks
    Check Injection Quantity
    Check Injector(s)
    Low reading MAF or intake leak (rather than boost leak)... intake leak will be sucking more air in and the adaption is adding fuel to keep the mixture right on cruise/idle (narrow band lambda on AGU)
  3. Markeyboy
    Markeyboy Fan of the R-Tech!
    282
    9
    My uncles old rover used to somthing similar to this, only on long journeys too. His turned out to be a blocked fuel filter that was slowly contracting the further down the road he drove until the car stalked due to lack of fuel, a coupple of mins with the engine off all would start n run fine again
    Might not be the same cause but might be worth a look
  4. <tuffty/>
    21,950
    4,227
  5. Gops
    3,198
    666
    Try a ultrasonic clean, change filter and if that hadn't cured it then go for a new maf!
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would say a dying pump, my first symptoms was bad starting if left overnight...
  7. AGU-TURBO
    616
    Thanks for the replies. Ive checked the fpr and its spotless. One thing ive never got round to doing is change the fuel filter so ill start with that i think. Ive been gathering parts for my k04 conversion and i have a vr6 maf Can i swap the sensor part over for the time being or will it read different?
  8. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Sensor should just swap straight over. It's the diameter of the housing that makes it read differently, sensors are the same.
  9. AGU-TURBO
    616
  10. vick_79
    vick_79 New Member
    Hello!
    you have the problem of "mixture adaptation" solved?
    I'm having the same problem on my A4 1.8T AEB
