ENGINE OVERHEATING HELP
german masterpiece Aug 24, 2008
  1. german masterpiece
    german masterpiece 2nd place is the 1st loser
    14
    hi guys im just after some advice. i havent been driving my car 4 ages as got a company van now. and went to use it the other day and it was overheating quite abit, ive had my mate who is a mechanic have a look and he has taken the thermostat out and has used a radiator cleaner but still overheats a bit, do you think its worth getting a new radiator ive heard that they're not to expensive, any advice would be grateful....:think:
  2. Siena
    Siena Active Member
    2,626
    It would help if you stated what car you have, what engine / model.
    Right now, all we can do is guess...and guess.....and guess.....:uhm:
  3. german masterpiece
    14
    erm yes soz i thought id put that on, muppet.:sorry: its an a4 20v 1.8 1996 model.
  4. Issac Hunt
    1,162
    Waterpump?
  5. aragorn
    18,149
    766
    mate recently had a vectra that was overheating and the waterpump had been fitted with a plastic impeller, impeller had basically snapped off the shaft so the pump was doing nothing...
    If its similar in design to the AEB though, check the little belt that runs between the waterpump pulley and the PAS pump, as if that went the only sign would be it badly overheating.
  6. Oranoco
    Oranoco Well-Known Member
    3,862
    381
    I'd be inclined to say waterpump.
    As has been said they use a plastic impeller which cracks and spins on the pumps shaft.
    Had it on my last A4
  7. mwarrey
    mwarrey Member
    280
    This is almost certainly what it is, quite common as well.
  8. aragorn
    18,149
    766
    Yer, something i never have fitted to an engine and never will (unless it becomes impossible to get metal ones), its quite a recent phenomenon, no doubt done to save about 50p during manufacture. I've found that the better parts suppliers tend to still be fitting proper metal impellers so if you look around you should be able to find a metal bladed replacement. I'd imagine (ok hope) that the genuine audi parts still have metal blades so that might be a last resort if you cant find one elsewhere.
  9. german masterpiece
    14
    thanks loads guys im going to have a look at that today:salute:
