Engine Overheating during idle.
GuyW Jul 11, 2011
  1. GuyW
    GuyW New Member
    21
    Hi,
    I have Audi A3 2.0 TDI (140) 05 plate.
    I was in London other day and got stuck in horrerous traffic barely 100 yards per 5 min! I even had gearbox in netural position, handbrake on when not moving and its suddenly went to 100 degree even its had a proper coolant liquid in and on maxmium level. Mind you that day was about 30 degree outside!
    When its got 100 degree and I put full heat on and its went back the normal temperature (middle. 50 degree if I remember correctly) then switch heat off its did happened again but when I am moving such as got out of London and its was on right temperature (middle) and never got overheating again.
    What fault could be for this? I am just concered as I don't like damaging my engine.
  2. symun
    symun Member
    147
    i thought it was normal for it to be around 90. if not then your fan may have packed up. if its just been renewed then it probably wasn't bled properly.
