Engine Oil Top-up - Advice needed
37 Feb 9, 2014
  1. 37
    37 Member
    129
    Hi,
    So my 1.6 Petrol was on Long life oil (personally not a fan but that is besides the point).
    Driving back home and low engine oil light came on and needs topping up. Service is not due for another 3 months and MOT is around that time too.
    So my question is:
    - Should I top up Now and wait for service or should I just go for Full service?
    - If its top up, can you recommend good oil and how much I should top up (1 ltr?)
  2. MorkC68
    MorkC68 Stationary
    171
    27
    if the oil light is on, it needs topping up regardless of time to the next service or risk it running out altogether, simple as. Top up should be however much it needs to get to the max mark on the dipstick!
  3. prt57
    prt57 Well-Known Member
    832
    252
    Add some top oil then allow it to drain through to the sump for a few minutes before wiping the dip stick clean then check the level. Repeat this until the level is correct and do not overfill. Check the manual to confirm where full is on the dip stick.
  4. Ch3tan
    Ch3tan Member
    60
    As above, top up now or just go for your service early.
    With regards to how to... run the engine for a few minutes idling on a flat surface. Turn off and let the engine cool for two minutes and then check the dipstick level by removing it, cleaning it and then plunging it and checking.
    If it's showing low then top up by no more than 500ml at a time and repeat the above to check the new level before adding anymore.
  5. 37
    37 Member
    129
    Recommendation for Engine Oil?
    Is this good?
  6. Ch3tan
    Ch3tan Member
    60
    Use discount code parts25 for 25% off at euro car parts. Audi use the Castrol edge stuff and that works out at 12quid after discount.
  7. aiwa_yamaha
    aiwa_yamaha Member
    31
    What happens if you go past the max mark about 3mm
  8. prt57
    832
    252
    I bought a TT 2.0 3 weeks ago and the oil was past the max by about 5mm. The car was booked in for a service and cam belt and I asked about it. The view was that with this amount over there was nothing to worry about. Just the week before they had had to drain a sump where the oil level sensor had broken and the elderly owner had over filled by about 3.0 litres as the sensor kept on indicating more oil was needed.
    Once drained out and sensor fixed there were no apparent lasting problems
  9. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,760
    Reduced at Tesco:
    Ch3tan likes this.
  10. aiwa_yamaha
    aiwa_yamaha Member
    31
    thanks
  11. stony2002
    stony2002 Member
    asda have the 4L drum on offer for £30, reduced from £38
  12. 37
    37 Member
    129
    Ended up buying from Lloyds motor spares for £35 4l (Only place close by). Didn't want to risk taking it out for a long drive!
