Engine number?
Lee Goodall Mar 1, 2010
  1. Lee Goodall
    Lee Goodall Active Member
    2,279
    Where do you find your engine number?
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    V5
  3. aragorn
    17,956
    701
    I have a pic! Took me ages to find mine, and its an absolute c**t to find once the engine is installed in the car!
    Its on that machined flat, which is on the nearside of the engine block, between cylinders 3 and 4. The only way you can actually read it with the engine fitted, is to remove the "Z" pipe (which attaches to that big hole you can see in the pic), which then allows you to get to the machined flat and clean it up. Numbers quite difficult to read as its stamped with dots. The manual says you can see it by looking down thru the inlet runners on 3 and 4, but i can only imagine this would only be possible on a new shiney engine block, not an old rusty one.
  4. Broken Byzan
    13,237
    465
    If it's for your car, it's correct i changed it when putting the new engine in
  5. Lee Goodall
    2,279
    The V5 matches the actual engine number? If so that'd be much easier as it looks like a right pain in the @ss to view properly on the block.
    I've declared all of the mods for insurance but I need the engine number too to complete the paperwork.
  6. Lee Goodall
    2,279
    Cheers Aragorn.. might be helpful for others in the future :icon_thumright:
