Engine number
low610 Jan 11, 2005
  1. low610
    low610 Member
    125
    Morning all,
    Does anyone know where the engine number is located.?
    My 99 A4 T sport has had a replacement engine and i want to check if it's the engine that has the waterpump running off the cambelt.
    Many thanks
  2. imported_Yaseen
    imported_Yaseen Guest
    remove the plastic engine cover and you shall find what you seek!
  3. low610
    low610 Member
    125
    Thanks Yaseen,
    Time to get dirty :)
  4. madkebab
    madkebab Member
    421
    If you dont want to get dirty it is printed on the inside cover of your service schedule book.
  5. madkebab
    madkebab Member
    421
    forget that as you have had a replacement engine!! doh
  6. low610
    low610 Member
    125
    Thanks anyway madkebab,
    I like taking things apart, it's putting them back together that's the problem. :)
  7. low610
    low610 Member
    125
    Evening all,
    Just looked under the engine cover for the engine numbers and found the following:
    Top left of engine - 06B 103 475 D
    Back of engine - 058 109 217
    Bottom block right side - 058 103 021 E
    There is also "APU" stamped at the top right hand side of the engine.
    I've just checked the log book and the original engine number was APU009454 which is nothing like the above.
    Any ideas guys.?
    Confused low610.
  8. madkebab
    madkebab Member
    421
    APU is your engine code.
  9. low610
    low610 Member
    125
    Nightmare!!!
    1 dealer says waterpump runs off cambelt.
    1 Audi specialist also says if does
    But 1 Audi specialist says it doesn't.
    Who are we supposed to believe. :)
