jordychris
i have noticed that on tickover the engine seems very noisey when outside of the car whether engine is cold or hot ie tappet noise maybe anyone noticed this
No, my engine is extremely quiet, inside and out, hot or cold.jordychris said:i have noticed that on tickover the engine seems very noisey when outside of the car whether engine is cold or hot ie tappet noise maybe anyone noticed this
rich1068 said:It is a very noisy engine. And I believe it is the injectors, a VAG specialist mentioned it in passing to me only the other day.
mfspen said:If yours is noisy, it is either defective, or it has been thrashed !
Then why is my engine quiet, and completely free from rattling of any kind ?RobinA3 said:...its the injector noise as i said in my previous reply.
the FSI engine uses very high pressure fuel injectors similar to new diesel engines.
Yes I agree.JamS3 said:It depends upon what experience you have had ie what cars exactly have you been used to that your are basing your comparison to?
No, I find it hard to see out of the windscreen with the bonnet raisedrich1068 said:...Have you tried lifting the bonnet?
Iv'e come from 2 8L S3's and at the min the noise seems more diesel than those on tickover.
HeliChris said:I am not even sure the TFSI uses hydrualic tappets, but if it does how many miles have your engines covered before the noise has developed?
I think if I was in your position, I would ask my dealer to demonstrate a couple of their 2.0T's. If you can't tell the difference, then that's end of story, but if your engine is significantly noisier, you would have a good case for a warranty claim.jordychris said:called into audi today asked technician to take a look at my car concerning injector noise and he confirmed this is a feature of fsi engine it is to do with the pressure the injectors are working under just as robina3 has said
