Engine mount replacement..how much? also odd oil leak
deanski Oct 21, 2011
  1. deanski
    deanski wax on, wax off
    369
    thinks its been going for a while but now the engine is rocking like crazy and you can push it from side to side by hand. Anyone had them done and how much would I be looking at? Also I have noticed there seems to be a small amount of oil around the base of where the oil filler is situated on the rocker cover. Its never been there before.
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    have just done one on my 2.5tdi. it cost £105 inc vat. i fitted it myself so all in 105. never tried one of these yet but turned out pretty easy.
  3. deanski
    369
    thanks for that. daft Q but do you need an engine hoist and did you have the same symptoms as me?
  4. swarcup
    1,326
    40
    nope i did it on a jack, i used a steel spreader plate then a plank of wood under the sump no problem at all. symptoms i had where a bad knocking noise and the engine was lifting on take off 3 to 4 inches as a guess
  5. marktdisport
    marktdisport Active Member
    1,195
    15
    mine thud's if your slight down hill and let of the throttle in 1st & 2nd at slow speeds guess mine needs one on the drivers side....
