Engine Mount N144
twist123 Dec 19, 2011
  1. twist123
    twist123 Member
    186
    Hi Guys,
    Front passenger side engine mount is showing as intermittent in VCDS as 35-10. Its the lower hydraulic mount, anybody experienced the intermittent value and fixed this?
    I have been quoted for replacement £245 fitted. Does this price seem reasonable from an independent VW specialist?
  2. simon.m
    simon.m Active Member
    2,747
    most of the time its just the wiers broken mate iv not had to buy one but that seems a lot more so as it would not be hard to change your self
  3. twist123
    twist123 Member
    186
    Thanks for replying Simon, so its just a case of taking the lower engine cover off and checking wiring for breaks? Did you also check the connector and clean it with WD40 or similar?
    Sorry to be a pain and ask another Q but from the mount where do the wires go, think theyre blue and red?
    Anybody who needs this specific part for a A4 1.9tdi AWX, I rang Audi its £106. £140 did sound like a lot for labour as it doesnt seem like it should take 2-3 hours to do.
  4. simon.m
    2,747
    no worries i cant rember where the wiers run as it was over a year ago ;-( you can see it from the top of the engine bay as well to clean any wiers i use an electrical solvent cleaner you can pick this up from most places i use maplin my self its 2 or 3 pounds i think. you any where near thanet ? i get trade
  5. twist123
    twist123 Member
    186
    Hi Simon, actually Im not to far away so if I needed the part that would be a great help. Will try clean as suggested first and take it from there. Cheers :)
    Shouldve chatted to you about the CCM I just bought that cost me £280 (facepalm!)
    I have now gotten a quote from a garage I use sometimes and they said about an hour labour which seems more reasonable to me, does anyone know if theyre any more of a pain to fit than a regular solid mount?
  6. simon.m
    2,747
    no worrys mate pm if you need it when i looked at mine it looked the same as any old engine mount so id say no harder to fit at all
  7. twist123
    twist123 Member
    186
    Great, thanks again for all the help.
  8. swarcup
    swarcup Well-Known Member
    1,326
    40
    i recently changed mine as it had sheared clean in half. £105 for the part and an hour of my time. Easy job to do yourself, i did mine on axle stands and used a jack to support the engine while i changed it
  9. twist123
    twist123 Member
    186
    Awesome, could you do me a step by step, like do I need to loosen top mounts etc. or just that one mount?
  10. quattrojames
    14,050
    576
    @ Swarcup...Thats a very popular question, if you get time to do it then I'll link it into the DIY Guides sticky.
  11. swarcup
    1,326
    40
    yes no problem will do one, although it will be for the 2,5tdi and cant vouch that other models will be the same. should be similar though
