Engine Mount Locations - 2.0TDi Quattro
ByronM Jul 27, 2009
  1. ByronM
    ByronM Member
    All,
    The girlfriends car has developed a slight vibration under certain loads, and as the DMF has been ruled out as the cause I want to check the condition of the engine and gearbox mounts as I am led to believe these are a weak point on the 8P?
    Can anyone provide an exploded diagram or pointers as to the locations and ease of access?
    Thanks in advance.
  2. tdisportuk
    tdisportuk Member
    460
    anyone with elaswin or etka can give you those mate. or just download it! and save yourself the hassle. Im away at the momment so cant help. Sorry.
    id get the all changed mate well esp the two top ones.
    what engine is it?
    if its a 2.0tdi the mounts are sh*t in them, engine rocks quite abit from factory!
    or as long as the broken ones changed and the rest are checked properly tightened and see if there's not much play within the mounting itself you should be fine mate.
    however yeah the 2.0tdi mounts are sh*t
  3. ByronM
    ByronM Member
    Where can I download it from? :uhm: Im in the trade, but 'not on floor' so to speak - so getting meaningful stuff like that is hassle at times.
    Its a 2.0 TDi 140 Quattro. Im hoping the knock/virbration is a dodgy mount, and with the A3's reputation of poor mounts it is a likely cause.
