Engine Misfire - Can't access spark plugs
silverswish Feb 21, 2011
  1. silverswish
    silverswish Black 1997 Audi A3 1.6
    My engine is slightly misfiring however I can only access two spark plugs because the inlet manifold is in front of the other two spark plugs. Is there a tutorial of how to access them?
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Huh? :think:
  3. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Inlet manifold?
    What engine do you have dude?
  4. Welly
    10,696
    127
    Must mean the N249 assembly - that's the only logical thing I can come up with...
  5. SiGainey
    SiGainey Member
    506
    9
  6. badger5
    9,424
    1,972
    what model car?
  7. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Previous posts suggest it's a 1997 1.6 A3.
    I know on my AVU engine 1.6 it's seriously tricky to change the middle two without taking the inlet manifold off. It IS possible though, I had to use a socket with two different extensions and a spark plug socket on the end and bend it and slowly work them out. Tricky, but it is doable.
    It could also be coilpacks or HT leads that cause a misfire.
  8. Welly
    10,696
    127
    Ahhhh, I see...
    For those who haven't ever seen one (like me) this would be the item in question then - ignore red circle.
  9. Dane
    4,086
    182
  10. S3KO4
    S3KO4 Member
    850
    Why don't you remove the inlent manifold then? does not look that hard!
  11. sportstractor
    sportstractor Chugger
    2,709
    EWWWWWWW
  12. TheButtonz
    TheButtonz Member
    97
    I changed mine about 1 year ago. I am a complete spanner, and it took me about 4 hours. The entire top bit (more evidence of my incompetence) had to come off, resulting in pistons showing etc. Behind the silver manifold in the centre of the picture are the delicate injector bar - this is all wires and sensors so be careful. As far as I can tell, the one on the passenger side is the only accessible one on the car. I literally took the whole top off to get to them!
    I changed due to a massive misfire but It didn't solve the problem, so I then changed the coil pack - still no luck. Then I discovered it was the HT lead. Moral of the story - when you do it -- do the lot if you can afford it.
    Sorry I can't be more help.
  13. TDIQ
    TDIQ 8L > 8P > 8V
    777
    That's the pic I took a long time ago, that is the heart of 100hp.
    I originally changed mine to stop a misfire, then the coilpack and it turned out to be a HT lead aswell.
