Engine Management Light
tally2425 Aug 18, 2013
  1. tally2425
    tally2425 Member
    157
    Drove my car earlier today was fine nothing different, got home and had to pop back out turned car on an noticed the engine management light stayed on as i was driving off, i can see no difference in the car nothing has changed and still drives fine.
    Should i be worried about this, i can still drive the car right?
    Also are the next steps i should take, could it be expensive?
  2. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,235
    392
    Next step is to get it scanned for the fault code.
  3. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Yep no point in guessing whats wrong until a scan is done :)
  4. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    As above, use the VCDS map and look for somebody close to you to scan it
  5. tally2425
    tally2425 Member
    157
    Thanks guys, i have a friend that could possibly scan it so that will be my next step! just hope it's nothing major!
  6. wuta3
    wuta3 Well-Known Member
    1,129
    347
    Seconded, get it scanned. My engine light came on and the code was a faulty sensor. Took it off and cleaned some dust out, sorted.
  7. tally2425
    tally2425 Member
    157
    i'm hoping it's something like that and nothing major, i'm going round my friends house tomorrow to get the code read. Will report back with my findings, wish me luck!
  8. tally2425
    tally2425 Member
    157
    Well guys here's the update i have the code P2279 and it says Intake air system leak, for some reason i don't think it's the air but a petrol leak as i can still smell petrol even though the garage said they had fixed it!
    The code i have can that mean anything else?
  9. Yonner
    Yonner Member
    155
  10. tally2425
    tally2425 Member
    157
    Brilliant so i could be right by saying it could be a petrol leak? as it says check all intake systems and it seems to be the fuel pipe leading into the engine?
  11. Yonner
    Yonner Member
    155
    Check all intake pipes one may be split , intake manifold ?
  12. tally2425
    tally2425 Member
    157
    Something is definitely split as i can hear it hissing when i put my bonnet after i turned my engine off just trying to find out which one it is will be the annoying part!
  13. LEE69
    2,235
    392
    Get a smoke test done if it evades you
  14. tally2425
    tally2425 Member
    157
    Well i found the problem.... this pipe isn't attached to anything, so first things first.
    What is this part called and where can i buy it from?
  15. Chillout
    Chillout Active Member
    610
    50
    That looks like a breather pipe you could get from audi or tps.
  16. tally2425
    tally2425 Member
    157
    Thanks i'll scout about or does anyone have one for sale? and who are TPS?
  17. tally2425
    tally2425 Member
    157
    can anyone give me the correct product name for this so i can try buy another one?
  18. Chillout
    610
    50
    Tps are trade part supplies if you go to audi they will show you a exploded diagram of your engine and hoses the part number is probably on the pipe
  19. tally2425
    tally2425 Member
    157
    I had a look on there but you have to sign up to see parts etc :( anywhere else to get parts? rather try get them from somewhere else other than get robbed by audi!
  20. Aidy06
    412
    19
    Have you even spoke to Audi to see how much the part is?
  21. tally2425
    tally2425 Member
    157
    Nope i'm just assuming it will be expensive haha!, i'll probs give them a ring only problem is i'm not sure exactly what 'Part' it is...
  22. Aidy06
    412
    19
    Try them, some things aren't as expensive as you'd think. The PN should be on that hose somewhere mate
  23. tally2425
    tally2425 Member
    157
    Well the pipe has snapped at both ends top and half way down the inlet (not sure how) i'm assuming the part number will be on the top?
  24. tally2425
    tally2425 Member
    157
    Another question, will i be doing some serious damage to the engine if i keep driving it like this? this is only temporary until i get a part sorted
  25. tally2425
    tally2425 Member
    157
    Double post, sorry.
