Engine Management Light Staying On
scoobyra Sep 14, 2010
  1. scoobyra
    scoobyra It's not f@cking ORANGE!!!!!
    798
    Just changed a coil pack and the EML has stayed on. This normally goes out when I've changed them before but for some reason it hasn't this time.
    Anyone got any bright ideas?
  2. gavin89
    gavin89 Wana go Low gotta go Slow
    214
    Get it scanned on Vagcom mate. Its the easiest way to tell. May need a reset?
  3. scoobyra
    798
    I will do just that when I get a chance Gavin. Just thought I'd ask if anyone knew if it resets itself?
  4. jdas03
    jdas03 Member
    603
    If u want to clear it disconnect the battery (make sure u have radio code) connect battery back up after a little bit and it should be gone unless the problem is more permanent in which case the light will re appear, that's what I did when I had a problem and it solved it :-D
  5. scoobyra
    798
    Its now reset itself!! Bloody thing!!
