Engine Management Light + Fault Codes - Help
leeds2592
When I grow up, I want a 964!
Leeds
Hi all,
The other day my Engine Management Light came on so I hooked up my VCDS, cleared the fault and went for a drive to see if it would come back on again. It did after 5 mins of driving. Car drives no different, however it does seem to be using more fuel (Unsure if this is related).
Anyway, the codes are below and I just want to know if anybody has any info on these or how to get it sorted?
Can post full scan if required.
Address 01: Engine Labels: Redir Fail!
Part No SW: 06F 906 056 FQ HW: 06F 906 056 EK
Component: MED9.5.10 G00 9503
Revision: 69H03--- Serial number: AUX7Z0F8FNE00U
Coding: 0000072
Shop #: WSC 06314 000 00000
VCID: 7DF7C5E8246C07F04A3
2 Faults Found:
000010 - Camshaft Positioner (Bank 1 Intake)
P000A - 008 - Slow Response - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 113985 km
Time Indication: 0
Date: 2013.01.08
Time: 09:36:35
Freeze Frame:
RPM: 760 /min
Load: 24.7 %
Speed: 46.0 km/h
Temperature: 45.0°C
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 114009 km
Time Indication: 0
Date: 2013.01.08
Time: 13:35:18
Freeze Frame:
RPM: 3400 /min
Load: 14.9 %
Speed: 92.0 km/h
Temperature: 72.0°C
Readiness: 0000 0100
Thanks in advance
Did you go into engine readiness and reset the MIL ?
I've not done that no, I've just gone through the Autoscan way and cleared the codes. How do I go about doing this? I'm pretty new to using VCDS.
Yeh, I've had a read of that but it's all a bit too technical for me. Getting camelt done in the next couple of weeks so may leave it for the garage to have a look at.
