engine management light and traction control light always on
martin9k Apr 11, 2010
  1. martin9k
    martin9k New Member
    engine management light and traction light is always on from yesterday had it fault read at kwick fit they said ecu was knakered then someone else read it and said its my oxygen sensor
    anyone know how to sort this or with the vag com?? ive only heard of vag com since joining this site
    but anyone have ideas of why trction control is constantly turned off??
    im in lincoln area if anyone has this vagcom and would be kind enough to use it on my car and see what they can do
    thanks guys
  2. Niknak
    Niknak Member
    867
    Have you checked your rear light cluster for bulb outs?
  3. martin9k
    martin9k New Member
    would that really put both lights on?? i shall check in a min
  4. martin9k
    martin9k New Member
    all rear lights wor
  5. h100vw
    h100vw Member
    218
    Generic code readers don't give enough info to work off mate. VAG-COM is the thing you need to do this job. I would be surprised if the ECU is done. Although engine faults do turn off "luxury" items. There was a lad here in Australia that had a bad MAF/air flow meter that caused ESP issues.
    Gavin
