Engine management light and ESP light on
AndyS3 Jun 4, 2005
  1. AndyS3
    AndyS3 Member
    133
    Anyone else had both on. They came on this morning after i was pushing prity hard round a bend that was getting tighter, instead of backing off i just pushed on knowing i would have no probs getting round the bend. When i exited the bend i lost all power momentarily. I then cruised down to a roundabout and the car count out. It started straight away, this was when the ESP light came on and the car was pulling to the left as if the ESP was applying the brake to the left front. Drove the car home and then the engine management light came on. The cars going ok, looks like i'll have to take a trip up to QST.
    Anyone else with similar experience?
  2. PaulRS3
    PaulRS3 Well-Known Member
    1,226
    153
    sounds similar to when i had a hose blow off mid bend, when hoofing it /ubbthreads/images/graemlins/grin.gif
    esp light come on and stayed on
    car had no power and switched to 2wd mode
    didnt have the pulling to (either way) fault tho
    was obvious blown hose, could hear turbo wheezing. as air leaked, and obvious hose hanging off in engine bay.
  3. jpda4
    jpda4 Member
    129
    21
    mine was the temperature sensor...... that was on the little 1.6 tho
  4. WilkoS5
    WilkoS5 Member
    166
    [ QUOTE ]
    [/ QUOTE ]
    This is what happened to me on Tuesday. The hose came off and the ESP light stayed on.
    The ESP light is still on, I don't understand why they should be linked /ubbthreads/images/graemlins/confused.gif
  5. grizz
    grizz Member
    50
    modern cars use "multiplexed" systems. basically some systems feed others data an vice versa. this is to cut down on the amount of sensors required in a modern vehicle. a fault in the engine could send out some wild data to the ESP which would log this and cause a fault.
    The fault just probably needs clearing.
  6. AL_B
    AL_B Well-Known Member Team Daytona Audi S3 DSG
    1,766
    208
    ESP light can also come on, and stay on, if there is a problem with the ABS or some sensors in the brake system. This occurred on my car, firstly, brake pedal pressure sendor sensor (something like that), and then another sensor buried in the brake servo system.
    AL
