engine management light 2001 2ltr
bob2312 Jan 12, 2012
  1. bob2312
    bob2312 Member
    42
    afternoon all ,EMS light came on last week also noticed that temp gauge stopped working and that the cooling fans are constantly on ,could be a connection i think,anyway car in garage to br sorted hoping for a cheap fix ,will keep informed about outcome ,was wondering if buying an odb connector and software was cost effective
  2. bob2312
    bob2312 Member
    42
    Collected car ,there were a few error code mostly to do with engine temps , main one being going into limp home mode and the result being the coolant fan being on constant, after a few tests it's being narrowed down to thermostat or a faulty sender, so the thermostat is going to be replaced, minimum 2-hours labour to replace so not the cheapest
  3. quattrojames
    14,050
    575
    Can't you replace the sender first if thats in question too?
  4. scottshere
    scottshere Member
    369
    That would be my first choice too... Change the sender. It isnt a hard job either, done in 20 mins
  5. bob2312
    bob2312 Member
    42
    Ok will speak to them
  6. bob2312
    bob2312 Member
    42
    hi all, well thermostat was knackered and also changed temp sender so 284 pounds lighter ,now at idle it blows cold air when above idle warm air so believe the water pump will need replacing so good job ive nearly stopped drinking
  7. scottshere
    scottshere Member
    369
    £284.... Ouch
    Im guessing you have the 2.5tdi at that price
  8. bob2312
    bob2312 Member
    42
    No 2.0 but the 20 valve version , anyhow took car for a quick blow on motorway everything seems fine , the replacement parts cost over £100 now all I've to sort is the radio as piss poor reception
