Engine Light came on.....Don't know what Vag Com Fault is about!
J.R. Feb 1, 2010
  1. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    I was driving today and the engine light came on...so I did a Vag Com test and it came up with this:
    18322 - Pressure Sensor for Brake Boost (G294): Implausible Signal
    P1914 - 002 - Lower Limit Exceeded - Intermittent
    Does anybody know what this means? As I can't find the meaning anywhere e.g google, Vag com Wiki..ect...
  2. NHN
    29,351
    1,720
    Did you clear this & then test to see if it came back, thats when you need to be concerned.
  3. J.R.
    1,405
    68
    An Update: I sorted out the (18322 - Pressure Sensor for Brake Boost (G294): Implausible Signal) it was a lose pipe in the engine. I now have a (00778 - Steering Angle Sensor (G85) 003 - Mechanical Failure) error which I need to check out. But i've googled it and know what to look for and i'm going to try and clean the sensor before I try and buy a new one to see what that do. I also got a (17811 - EGR System: Regulation Deviation P1403 - 008 - Implausible Signal) error but I know what that is......I need a new EGR... thanks for your help NHN ...
  4. NHN
    29,351
    1,720
    Do a steering angle calibration 1st & see if faults clear, if not PM me as I have a spare steering angle sensor for sale if needed.
  5. J.R.
    1,405
    68
    How do you do a "steering angle calibration" ?
  6. NHN
    29,351
    1,720
  7. J.R.
    1,405
    68
  8. NHN
    29,351
    1,720
    Use the thanks button if someone helps you mate & I dont mean just myself, just shows courteousy mate, thanks.
  9. J.R.
    1,405
    68
    I’ve just tried this out and I get to this stage: Enter 40168, to enable the basic setting. Then I get this error in the picture below:
    Basic Setting
    Sensor for Steering Angle (G85)
    Prerequisites:
    • Start the vehicle.
    • Turn the steering wheel one turn to the right and one turn to the left.
    • Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
    • If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
    • Ensure that the steering wheel is not moved again.
    • Keep the engine running and do not switch off the ignition.
    • System voltage at least 12.0 V.
    [Select]
    [03 - Brake Electronics]
    [Coding-II - 11]
    OR (if Coding-II is not available)
    [Security Access - 16]
    [Do it!]
    [​IMG][​IMG]
