Engine Idling / tick over Problem
taff68 Mar 26, 2014
  1. taff68
    taff68 New Member
    24
    Hi,
    Every now and again whilst sitting in traffic, the engine in my A6 2L TDI, 2010 s-line 170bhp, seems to jump between the low idle setting, approx.900rpm and then up to 1000 rpm and then settle down again back to 900rpm? Only happens occasionally?
    Is it just a case of asking garage to adjust tick over setting or something more serious?
    Thanks,
    Taff68
  2. saxonblue
    saxonblue Member
    298
    15
    mine has done the very same thing, but then it seems ok for weeks on end,
    I ran my fault Code reader through it and it came up with a map sensor problem ( map = manifold air pressure ...I think)
    could it be the same on yours?
    :shrug:
  3. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,005
    765
    Had a similar on one of my old A4's turned out to be the MAF, best get it scanned to see if a fault code appears. One thing to note there was no fault code with my faulty MAF.
  4. saxonblue
    saxonblue Member
    298
    15
    worth a scan anyway, as you never know, I was told mine could be the MAF. but then I was told no it cant ..coz its not got 1:shrug:
  5. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    MAF or DPF regen happening if it doesn't do it all the time.
    Get it scanned.
