Engine drag from AC?
Glyn E Jul 3, 2012
  1. Glyn E
    Glyn E New Member
    A3 2.0 SE TDi 170 2008 model. Auto climate control.
    As soon as I switch on my AC unit The drag on the engine is enough to make it run roughly and appear to lack power. It certainly is nowhere near as smooth to drive with it switched on.
    It makes no difference what temperature is set, the drag is the same.
    With all other cars I have owned with AC fitted, there has been no noticeable change at all when AC is switched on.
    Is this common or normal, or do I have a fault somewhere? There are no fault codes showing.
  2. Ash187
    7,505
    748
    i think its common for a slight bit of power loss when the Ac is on, but it doesnt feel rough in mine when i switch it on
  3. mjr901
    mjr901 Guest
    I seem to remember when your idle, and you switch AC on the revs dip briefly, thus changing engine note, but power wise I think it's steals something like 5-10% of yours cars power.
    its a thirsty bit of equipment!
  4. Zak0123
    Zak0123 Active Member
    540
    77
    Bit different but my old Peugeot 206 2004 plate used to drag slightly when AC was switched on...
  5. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    It is normal to feel a chang in the way the engine runs when you switch on the AC but with 170 HP and at least 350NM of torque this shouldn't be THAT noticeable.
  6. BlueTDI
    BlueTDI New Member
    I have noticed this now the weather is warmer and the AC unit runs.
    Does anyone know if a AC recharge/regass will help reduce the drag?
  7. Old-Boy-Racer
    Old-Boy-Racer Guest
    I can barely detect any change with mine - before remap or after.
  8. Vertigo1
    Vertigo1 Well-Known Member
    3,663
    746
    Never noticed this on any of my three A3s - I'd get it looked at.
  9. RPB
    RPB Active Member Team Ibis Audi S3 Black Edition DSG
    401
    70
    Don't notice it on my S3, but my modified Subaru was a pig to drive with it on! Changed the pedal feel big time and was noticeable.
  10. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Mine feels different with ac on really sluggish
  11. cjsuk
    cjsuk Active Member
    567
    80
    Most cars ive had with aircon on have run rough on idle, and taken power. It depends how rough and how much power loss is, and even if the aircon was really shafted I cant see how it can make more of a power loss or rougher idle.
  12. Vertigo1
    3,663
    746
    The thing I don't understand is, how do you know when the aircon is "on"?
    With climate control, whilst you can disable the aircon compressor via the ECON or AC button, if you leave it to its own devices, then it's up to the climate control system whether the compressor is needed or not. In this situation, I've not once noticed any detectable change in performance or responsiveness that would indicate whether the compressor is engaged or not.
  13. Minstadave
    Minstadave Member
    560
    19
    Econ turns AC off completely, atleast it does on mine.
  14. cjsuk
    cjsuk Active Member
    567
    80
    I have a bit of a noisy compressor so I know mine is on, if I leave the climate control on auto, the compressor is allways on no matter weather its its got to its temperature or not its only off when I press off or econ, so if you have it on auto all the time, you wont notice a difference as its allways on.
  15. audicruiser
    audicruiser Audi Heaven
    1,865
    It shouldn't be running all the time unless you have the temp set really low on a warm day... It should cut in and out.
  16. Vertigo1
    3,663
    746
    I know, that's what I said. What I mean is, unless you disable it completely via the ECON or AC button, there's no way to know whether the compressor is actually on as it's up to the climate to decide and there's no indicator to tell you.
  17. 964kevin
    964kevin Member
    109
    Makes no diffeence to mine, though you can see how much fuel it takes to run on the DIS, about 1/12th gallon per hour if memory serves.
    K
  18. CornRattle
    CornRattle Member
    151
    When I turn the AC on my 2010 S3 the revs on idle pick up ever so slightly, no noticeable difference on running though
