engine differences between S3 and 1.8TQ
JamesA3 Apr 12, 2004
  1. JamesA3
    JamesA3 Member
    238
    I thought the 180bhp 1.8TQ engine was a detuned version of the 210bhp S3 engine and the 225bhp S3 engine was the same as the TT
    could someone clarify for me please
  2. Ess_Three
    Ess_Three Active Member
    5,383
    No, 210 S3 is basically the same as a s3 / TT 225...both chip up to the same although there are slight differences between the two.
    The 180 engine is more like a Golf / A3 150 but with a slightly better turbo.
    The 180 is NOT as strong (bottom end) as a 210 / 225...nowhere close, and hence you can't take the same liberties with it when tuning.
  3. Aurom
    Aurom New Member
    As I understand it the 1.8TQ has the same basic engine as the 1.8T with a KKK K03 turbocharger and single intercooler. Its ecu is mapped to give 180 bhp rather than 150.
    The unit that they fit to the S3 & TT is didderent with a KKK K04 turbocharger, twin intercoolers, and stronger pistons and con rods (i'm sure there are some other small differences as well).
    I dont believe that there is any difference between the 210 S3 and the 225 except the ecu programming?
    can anyone add to this?
  4. JamesA3
    JamesA3 Member
    238
    thanks for the info
  5. JamesA3
    JamesA3 Member
    238
    if the 1.8TQ isn't as strong is 215bhp within its limits or is it really starting to strain the engine?
  6. PaulRS3
    PaulRS3 Well-Known Member
    1,218
    150
    also things like twin cats etc on the S3.
    intake manifold round the other way on the non 210.225 engines due to only having one IC
    after run pump is also fitted on the 210/225 lump to circulate coolant round the turbo jacket to help take heat away when engine is shut down
    There are subtle diffenced im told with the way VVT works between the 210 and facelift 225 engines.
    mine is solenoid driven electrically, im told the earlier 210's were oil pressure driven...
  7. Ryanc
    Ryanc Active Member
    1,321
    mahle pistons ,stronger rods,k04 turbo
  8. Drill
    Drill Member
    928
    Paul, just FYI, some of the 150/180 hp versions of the 1.8T had twin-cats as well, but since the S3 and 1.8TQ have different sized exhausts (S3 being larger) the part numbers are different, as the cats are larger /ubbthreads/images/graemlins/grin.gif
    /ubbthreads/images/graemlins/beerchug.gif
  9. PaulRS3
    1,218
    150
    /ubbthreads/images/graemlins/beerchug.gif careful mate thats on topic /ubbthreads/images/graemlins/lol.gif
  10. manueltrigo
    manueltrigo New Member
    Think that Aurom is right. Although the general architecture of A3 and S3 engine is the same, some differences in camshaft, turbo size, intercooler and specially in ECU to provide 215/225 HP in S3. As 150/180 HP are basically the same with different programm to get 0,8 bar of turbo blow pressure (instead of 0,5 in 150), in S3 they must be applied the same procedure; new reprogramming and calibration of valves to increase blow pressure.
    Essentially the same engine. That´s what you do when remapping....
  11. Drill
    Drill Member
    928
    [ QUOTE ]
    [/ QUOTE ]
    /ubbthreads/images/graemlins/shocked2.gif Good point, I won't tell anyone if you won't /ubbthreads/images/graemlins/angel.gif /ubbthreads/images/graemlins/smile_smoking.gif
    /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/beerchug.gif
  12. JamesA3
    JamesA3 Member
    238
    just been looking at the turbo upgrades on Jabba's website and they reckon my engine is good for 350bhp 300lb ft with no internal mods to the engine and with mods 550bhp can be achieved. Conrods need upgrading beyond 335lb ft so I think I have been worrying over nothing
  13. Alonzo
    Alonzo Member
    151
    [ QUOTE ]
    [/ QUOTE ]
    I think correctly translated thats putting a fighter jet engine into the car /ubbthreads/images/graemlins/jawdrop.gif
  14. ANDYTQ
    ANDYTQ Well-Known Member
    1,184
    105
    180's have KO3 SPORT turbos ,which is a larger unit,or at least mine has one.As Drills says twin cats,although i looked at the shape of the front pipe/cats the other day and it looks very restrictive 1 into 2 and then back into 1 ?.Am having a 3" downpipe made up with a 200 cell cat,should improve flow.Cheers Andy.
  15. Drill
    Drill Member
    928
    AH, but the 180 versions, when tuned, get the same results as the 150 versions /ubbthreads/images/graemlins/smile_smoking.gif
    Here's some engine code info I found on www.briskoda.net:
    [ QUOTE ]
    AUM (Octavia 1.8T FWD):
    150 hp
    FWD
    VVT, EU4
    DBW
    smaller injectors
    hybrid K03/04 turbo
    AUQ (Octavia RS, Leon Topsport)
    180 hp
    FWD
    VVT, EU4
    DBW
    bigger injectors
    hybrid K03/04 turbo
    ARX (Octavia 4x4)
    150 hp
    Haldex
    VVT, EU3
    DBW
    bigger injectors
    hybrid K03/04 turbo
    ARY (Leon 4)
    180 hp
    Haldex
    non-VVT, EU3
    DBW?
    bigger injectors
    hybrid K03/04 turbo
    [/ QUOTE ]
    And as the range of VAG engines is pretty much the same (Excluding the TT/S3 ones) then it appears that while the 180 DOES sport a K03S, it does NOT have VVT whereas the 150 (ARX) version has both /ubbthreads/images/graemlins/grin.gif
    /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/beerchug.gif
    And for some more info on the 4 different versions of the 1.8T in the A3 you can look HERE /ubbthreads/images/graemlins/grin.gif
