engine cover for s3 sportback after the air intake mod?
kinson Feb 12, 2011
  1. kinson
    kinson Member
    73
    have been thinking about doing something with the air in-take system on the s3 sportback. however the stock in-take system forms part of the engine cover... and i do not prefer to keep a engine cover even if the air intake system is changed... what choices do i have?
    :unsure:
  2. tku
    tku Member
    630
    That didn't make sense sorry. So are you looking for an intake where you don't have to leave engine cover off or are you not bothered? . Anyways, I wouldn't compromise with the intake and go for iTG maxogen or forge twintake. Or evoms if you want slightly less power gains but an incredible sound. Unless you adapt your cover it will have to come off. Although who cares as how often do people even look in their bonnet.
  3. kinson
    kinson Member
    73
    I am really looking for retaining a engine cover even after the in-take is modified... I could be wrong... but had the impression of the engine cover will help in absorbing the engine's vibration and heat shield, especially when the sun shines directly on the bonnet (car is parked outdoor)... that is the main reason I would wish to have the engine cover...
  4. brough74
    brough74 Member
    423
    22
    The only intake that keeps the engine cover is the carbonio one (but people dont recomend them), all the others will need the cover trimmed down to fit. My cover is trimmed to fit with my intake and i looks ok, much better than no engine cover at all.
  5. jungleman
    jungleman Well-Known Member
    2,035
    42
    to be honest the engine cover does nothing but keep bits of the engine a little cleaner, once you have fitted the air intake you can cut the old engine cover to size so it fits around the new intake, but its not needed
  6. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    Did mine this weekend and it takes quite a lot of trimming and adjustment to get the perfect fit. You have to cut it slowly and carefully as I used a grinder and the plastic kept melting!!
  7. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    All about the evoms engine cover! Gonna get mine once I'm finished playing with the engine! + r8 oil cap:wub:
  8. jungleman
    2,035
    42
    i dunno its a lot of money for a bent bit of aluminium, would rather try and find a nice carbon one personally, but cant find any :(
    agree with you tho on the oil cap!
  9. S3RYE
    3,448
    70
    true but as you said not many options about...! ill defo go dwn this route to tidy it all up!
  10. nelson19uk
    nelson19uk There's no poke without smoke!
    152
  11. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    I have one, PM me with an offer!
  12. Karadjas
    Karadjas New Member
    25
    Search for neuspeed, i'm getting the half-sized one when I get my intake (assuming the cover will fit, not sure yet)
    Neuspeed full cover
    Neuspeed half cover
  13. Lambchop
    Lambchop New Member
    15
    James - Do you have any pics of your modded engine cover ?
  14. JamesS4cab
    1,191
    94
    Will take some when I get 5 mins and post up for you.
  15. sturs4
    sturs4 Member
    193
    9
    Just get yourself a ITG induction kit and keep the cover off and keep it to 1 side if you put it back to standard.You wont be bothered once you put you foot down then change gear.if you keep the engine bay clean it still looks good.
