Engine Coolant Temperature Sensor (G62)
gaanrowl Nov 29, 2009
  1. gaanrowl
    gaanrowl New Member
    19
    hi all on the way home from newcastle today my engine coolant temp sensor was on constantly, fortunatly my brother has diagnostics on his computer it has threw up the fault code and this is the result.
    http://wiki.ross-tech.com/index.php/17664/P1256
    has anyone got the part number or knows where i can get one?
    also where abouts is it on the engine will it be possible to fit it myself.
    cheers.
  2. nmahi
    nmahi New Member
    15
    i would be guess, so please dont shoot me down if im wrong...but on the 2.0l its at the back of the engine. pretty easy to change...take of the cover and various pipes (for space) the temp sensor sits on top of the flange (is green). unclip the connector, pull and remove the house shoe clip forward and it pulls out, remember to change the seal too. you'll need to bleed the coolant, to get any air locks out, then clear the fault on vag.com.
  3. nmahi
    nmahi New Member
    15
    p.s, it cost me £28.38 for sensor and seal.
    part numbers from TPS:
    sensors - S059919501A
    seal - N90316802
    TPS or Audi or maybe eurocarparts.
  4. gaanrowl
    gaanrowl New Member
    19
  5. nmahi
    nmahi New Member
    15
