Engine coding failing
mramage Sep 15, 2013
  1. mramage
    mramage Member
    516
    This has been driving me mad for the last 2 months!! I retrofitted cruise control (2009 s3 stronic facelift) no probs. the steering wheel coded fine and diag shows all buttons working ok.
    The problem is the engine coding. Setting the cruise control bit just doesn't seem to take. I've tried doing them in different orders, ignition off and on, ignition left off and the apparently sometimes needed TBA. It says coding accepted, but then it just doesn't work. When I reopen the coding the bit is unset again, even after all the things above. It's really weird. Just wondered if anyone had seen anything similar.
    I should say this is not a genuine cable in use. If people have seen issues like this I guess it would be a good reason for buying the proper one!
  2. Chillout
    Chillout Active Member
    610
    50
    I have a genuine lead I live near Aberdeen if your near i could help ,I would advise buying one from nhn on here am sure he will give you a good deal and assistance.
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    Have you actually activated it?
    [Select]
    [01 - Engine]
    [Login - 11]
    Enter 11463 to activate cruise control
    [Do It!]
    After doing this procedure, there should be a letter "G" in the Component field.
    Try doing that first then changing the coding in 16/steering wheel.
  4. mramage
    mramage Member
    516
    It's a different coding style for the diesels, the s3 uses the long coding cruise control bit setting.
    Chillout, thanks, bit far away though!!!!
  5. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Log in to engine module, long coding activate cruise, do it, when it says coding accepted, log out of engine mode completely, turn ignition off, and take out key, wait at least "30 secs" then put key in ignition on, then take for a spin. I have retrofitted well over a hundred on various Audi's and has worked 100% of the time for me. If this still does not work, then the problem may lie deeper, and perhaps need further investigation, as for some reason, your engine module does not want to keep the coding stored.
    ATB
  6. mramage
    mramage Member
    516
    Seems it is the cable. Don't trust the copies!!!!!! Stirling audi kindly activated it for free when car was in :)
  7. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,197
    2,013
    Sorry for off topic but your avatar is awesome mramage
  8. mramage
    mramage Member
    516
    Cheers. It's McLaren F1 engine. I defected to BMW for a while and had an e46 M3. Apparently the F1 is 2x those engines as basis.
