Engine Code explanations
SnoopS3 Oct 13, 2009
  1. SnoopS3
    SnoopS3 You cant beat German
    69
    hello folks,
    It seems my car has found out i was thinking of selling it and has decided to spew out some Fault Codes.
    Could any of you fine people please give me an explanation of what the codes are and what the probable faults would be?
    Codes as follows:
    18010
    17522
    17526
    01279
    thanks in advance
    (just realised i posted this in the 8P forum by accident! it was 7:30 am i'm allowed)
  2. <tuffty/>
    21,964
    4,230
  3. Broken Byzan
    13,244
    468
  4. Westy
    Westy Well-Known Member
    17,443
    1,105
    too slow Mark!
  5. <tuffty/>
    21,964
    4,230
    ...but at least its a Quattro now mate :icon_thumright:
  6. SnoopS3
    69
    Dammit!! I cant get on that site at work!
  7. <tuffty/>
    21,964
    4,230
    18010/P1602/005634 - Power Supply B+ Terminal 30: Voltage too Low
    Possible Causes
    * Cables on the Battery were removed
    * Battery weak (voltage)
    * Generator Disfunction
    Possible Solutions
    * Check Battery Cables
    * Check/Replace Battery
    * Check/Replace Generator
    Special Notes
    * If multiple Control Module have Power Supply Faults stored, it's most likely to be one common Problem like the ones shown above. Otherwise when only one or two Control Modules have such Codes stored you better start searching at the individual Power Supply of these Modules.
    Can't find a reference for this one
    17526/P1118/004376 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
    Possible Symptoms
    * Malfunction Indicator Light (MIL) faulty
    Possible Causes
    * Wiring/Connectors from/to Oxygen (Lambda) Sensor Bank 1 Sensor 2 Heating faulty
    * Oxygen (Lambda) Sensor Bank 1 Sensor 2 Heating Circuit faulty
    Possible Solutions
    * Check Wiring/Connectors from/to Oxygen (Lambda) Sensor Bank 1 Sensor 2 Heating
    * Check Oxygen (Lambda) Sensor Bank 1 Sensor 2 Heating Circuit
    01279 - Longitudinal Acceleration Sensor (G251)
    01279 - Longitudinal Acceleration Sensor (G251): Implausible Signal
    Possible Symptoms
    * Malfunction Indicator Lamp (MIL) active
    Possible Causes
    * Longitudinal Acceleration Sensor (G251) Calibration not performed
    * Wiring/Connectors from/to Longitudinal Acceleration Sensor (G251) faulty
    Possible Solutions
    * Check Longitudinal Acceleration Sensor (G251)
    o Use Measuring Value Blocks (MVB) to check Sensor Signal for plausibility
    o Check Installation Position of Longitudinal Acceleration Sensor (G251)
    * Perform Longitudinal Acceleration Sensor (G251) Calibration
    o See Vehicle specific Diagnostic Procedures
    * Check Wiring/Connectors from/to Longitudinal Acceleration Sensor (G251)
    01279 - Longitudinal Acceleration Sensor (G251): No or Incorrect Basic Setting / Adaptation
    Possible Causes
    * Longitudinal Acceleration Sensor (G251) Basic Setting lost/not performed
    Possible Solutions
    * Perform Longitudinal Acceleration Sensor (G251) Basic Setting
    o See Vehicle specific Diagnostic Procedures for Details
  8. Westy
    17,443
    1,105
    Did you get bored Paul? You're not impressing anyone with your copy and paste skills :)
  9. Broken Byzan
    13,244
    468
    I think he is just showing off he can access the WIKI from work,lol
  10. <tuffty/>
    21,964
    4,230
    I dunno... you try and be helpful LOL
  11. Westy
    17,443
    1,105
    HAha. I think the link was very helpful mate. Now you're just spoon feeding.
  12. SnoopS3
    69
    Not that helpful at work :)
    Tuffty that is legendary! thanks so much for that. Will need to checn a hook of sensors now.....great :think:
  13. LordNelson
    LordNelson Member
    167
    I have a fault code 01279 Longitudinal acceleration sensor too. this could also be linked to my airbag fault code of 65535 (aparantly).
    so my question is....what and where is the Longitudingal Acceleration Sensor?
