Enabling TPMS for A3 S3 8V *Experimental*
veeeight Apr 30, 2014
  1. Schizophonic
    Schizophonic Well-Known Member
    954
    485
    The menus for the mmi all appeared regardless of the fault codes but the options were grayed out. With the engine running part, I normally turn the ignition once to start the electrics. Should I be leaving the engine running when I set the codes? I.E. Turn engine fully on and begin coding?
    Also with the 308805, the fault in my dash kept on appearing where as if I tried 208805 I didn't get the error on my DIS.
  2. ChiYoung
    ChiYoung Active Member
    148
    41
    Then they might have changed something but it seems unusual as mine is also a 2013 sportback
    your option to go should then be 208805.
    Anyways im sorry but i cant help any more, im sure somebody has another idea to try.
  3. Alan Porter
    Alan Porter New Member
    Hi,
    I have a 2013 Sportback with all the assistance extras (except TPMS) and my long coding is:
    12F18AA220250A70017A060101C9294851045080608094F2F879500805
    I noticed the two numbers I need to change (highlighted in bold) are 0 for all the other posts on here but mine are 5 & 0. Should I be adding to these numbers or just simply changing them to 3 & 8 ?
  4. AudiNutta
    AudiNutta Well-Known Member Team Racing Blue Mica Audi RS3 quattro Sportback
    4,780
    2,979
    I have issues with mine, I had it activated but it never appeared to work because the MMI menu shows TPMS.. But won't let me open it, it says unavailable.
    But now today I had a flat and surprise surprise it flagged up, which was pretty cool!! But now I have a problem, I can't access the menu to reset it :-( I am going to try and master reset the MMI and hope for the best.
    But, does anyone have any idea why it might just not be opening the menu? Very thankful for any help please!! The car is going into Audi a week tomorrow and it can't go in with the light on, because if it does and they try to reset it they will realise I've messed with it haha. My programming guy isn't playing ball :-(
  5. DJAlix
    DJAlix VAG Car Coding Site Sponsor Team Ibis VAG Can Professional VCDS Map User Gold Supporter quattro ODIS (Offboard Diagnostic System)
    3,254
    2,657
    To save me from reading the complete thread could you post up the steps you used to code TPMS so I can see if anything has been missed.
  6. Marchal
    Marchal New Member
    Hello
    I would like to activate tpms Audi A3 8V sline 2013
    My long coding ABS is 12F162A220280A6D017D060301C4294846045080608094F20279000405
    what changes should I do in the code?
    Thank you
    Kalashnikov likes this.
  7. DJAlix
    3,254
    2,657
    You only have 29 Bytes within your ABS module so it might not be possible:
    • 5F - Information Elect
    • Adaptations
    • (56) vehicle_menu-operation-menu_display_rdk = Activated
    • (13) vehicle_function list BAP; extension-tite_pressure_system_0x07 = Activated
    • 17 - Instruments
    • Long Coding
    • Byte 4
    • Bit 0 = Enable
    • 03 - ABS Brakes
    • Coding
    • 12F162A220280A6D017D060301C4294846045080608094F2027900348508
    *Note: The 08 on the end of this coding = Byte 30.
    1. Disconnect VCDS
    2. Reset MMI
    3. Turn Off Ignition
    4. Start Engine and leave for 1 min before turning off the engine again.
    5. Turn ignition to 1st position.
    6. Test by going to the MMI Service Menu.
  8. Marchal
    Marchal New Member
    thank you for your response djalix do I add the 30 byte without problem after ? thank you in advance
  9. DJAlix
    3,254
    2,657
    If I was performing the coding myself I would probably test in the following order:
    1. Change bytes 28 and 29. If accepted then test as per steps 1 to 6 above.
    2. If 1 is not accepted then I would try adding byte 30, while making sure that soft reset is ticked.
    3. If 2 is accepted then I would then change bytes 28 and 29 and then test as per 1 to 6 above.
    If none of this works then your ABS module will need updating or possibly changing. Just out of interest can you post up the details of your ABS module?
  10. Marchal
    Marchal New Member
    is there a risk of breaking the abs with bad coding ?
  11. DJAlix
    3,254
    2,657
    There is always a risk of causing issues.
    If you can run an autoscan and post up all the details for 03 - ABS I can see more of what might be possible before you make any changes.
  12. Marchal
    Marchal New Member
    Adresse 03: Freins ABS (J104) Labels: 5Q0-907-379-IPB-V1.clb
    No. pièce Log: 5Q0 907 379 AC Mat: 5Q0 907 379 D
    Pièce: ESC H75 0437
    Révision: 00000000 No. de série:
    Codage: 12F162A220280A6D017D060301C4294846045080608094F20279000405
    No. Atelier: WSC 06314 790 00021
    Jeu de données ASAM: EV_Brake1UDSContiMK100IPB 008020
    ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
    VCID: 7DF18B0EECEB62D615-8028
  13. DJAlix
    3,254
    2,657
    What year is your car?
  14. Marchal
    Marchal New Member
  15. DJAlix
    3,254
    2,657
    Done a little digging around and cannot find too much information on your module. In its current state (software version) it looks like it might not possible to activate TPMS (PR-7K0).
  16. Marchal
    Marchal New Member
    Thank you for all djalix
    it works perfectly without the byte 30
    When I want to add the 30 byte it does not want
    but I have the menu to reset the tpms
    thank you very much
  17. DJAlix
    3,254
    2,657
    That is surprising and really good news! Thanks for letting us know :)
  18. Schizophonic
    954
    485
    Sweet. Now to test on mine. I know we didn't get this working last time.
    Sent from my Nexus 6 using Tapatalk
  19. Kalashnikov
    Kalashnikov Active Member
    232
    44
    hey how did you get it working on your car, i have the symbol blinking in the cliuser and the menu option is greyed out the moment.
    12F18AA220250A720179060501C92548510450806080A4F20259000405 same code as yours
    any help appreciated
  20. Kalashnikov
    232
    44
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
    Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
    Component: ESC H75 0437
    Revision: 00000000 Serial number:
    Coding: 12F18AA220250A720179060501C92548510450806080A4F20259000405
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
    VCID: 7DF789B6EC8604F6FF5-8028
  21. Kalashnikov
    232
    44
    answered my own question. for 29 byte ABS modules
    example of the original code
    12F162A224250A720178060841CC2548462450806082A4F2004100080508
    New code should look like these
    12F162A224250A720178060841CC2548462450806082A4F2004100388508
    DJAlix likes this.
  22. diegoweb
    diegoweb New Member
    hi! i've successfuly enable tpms on my 2013 8v Sportback, i've the yellow icon, mmi menu and i can store the data but when i tested ('ve drive some km with deflated wheel) it does not indicate the problem! Can you help me?
    Original:
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Coding: 12F162A220220A75037D060101C52948460450C0608094F3F4 79500405
    VCID: 7DF661DBECE2C9D636-8029
    No fault code found.
    MOD.:
    Coding: 12F162A220220A75037D060101C52948460450C0608094F3F4 79503485
  23. Hi everyone , I am new here. Please indicate if these tests were made with micro Can cable or some other device..
  24. Hi veeeight, please indicate what vcds's cable did you use for these test.. thank you
  25. Matti991
    Matti991 New Member
    Diego, look at this ;)
    When you turn on the ignition, you should see the TPMS light briefly turn on. The system needs at least 1 hour of driving including on the highway to adapt. During that time the TPMS may not be reliable.
  26. shazad manzoor
    shazad manzoor New Member
    25
    Hi
    Hi veeeight, trying to get tpms working on my wife's car but having no luck. Main problem is I am unable to find out the line where it says extension_tyre_pressure. Have managed to get yellow tyre pressure icon on dash and reset tyre pressure on pop up screen but it's greyed out any help would be great
  27. shazad manzoor
    25
    Hi Chi Young in your post 13 extension-tire_pressure line is not in my drop down menu is missing on my car is there any way I can get this there. It's almost complete done on my car apart from that any help would be great cheers.
  28. brumble
    brumble New Member
    Hi Shazad Manzoor,
    I am facing the same issue as you as well. I am on Ross-Tech hex-v2 cable running VCDS Beta v17.6. I was able to find and enable most of the suggested menu and feature within Module 5F and Module 17 Instruments, however my coding were different from the ones listed in this thread and other forums posts, after some trial and error, I managed to get tyre pressure icon showing on dash, tyre pressure menu on dash and MMI showing the greyed out option to set tire pressure. I'm not sure if you have managed to resolve it on your end, if you do, it would be nice to share your method to get it working.
    I am hoping someone could kindly advise us if its the coding that is causing this greyed out option? I'm on Audi A3 8V Facelift Non-Navi MMI, manufactured in 2016. I believe its on MIB2 platform.
    Thank you in advance!
  29. shazad manzoor
    25
    Hi Brumble guy who tried to do my tpms got as far as you did. In the end I have contacted a member on her called Alex from vag car coding and have arranged for him to carry out my tpms and a few other other bits of coding. I highly recommend Alex as he is very experienced in what he does. If you can find him on her and PM him he will tell you what you need to do.
  30. brumble
    brumble New Member
    hi Shazad Manzoor, really appreciate your prompt reply. I'll try to find Alex then and will post back my findings if its resolved. Thank you!
  31. shazad manzoor
    25
    No worries brumble, Alex was kind enough to reply to me and help me out. He regularly attends VAG shows around the country so you can contact him and arrange a meet or go to him he is based in London.
  32. shazad manzoor
    25
    Brumble please see photo
  33. audia38l1
    audia38l1 New Member
    27
    Hi Guys,
    Could any Audi s3 8V facelift owner shared the ABS module long code? I really want to enable the factory TPMS as mine doesn't come with it in my region. After reviewing almost all the related posts, I am still having trouble to understand which bytes/bits should be changed/enabled.
    By looking at my ABS module long code down below, it looks so much different than the one with the pre-facelift available in the forums:
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 8V0 907 379 B HW: 8V0 907 379 B
    Component: ESC H25 0610
    Revision: 00000000 Serial number: 62756000000252
    Coding: 329C938D54A01BAA89910B64419A694CC92AD891D082967600410004020812
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
    ROD: EV_Brake1UDSContiMK100IPB_035_AU37.rod
    VCID: 43D047A28B17CD7F068-8016
    Anyone can help me out?
  34. shazad manzoor
    25
    Hi there
    Contact Alex from Vag Car Coding he will put you right.....
  35. DJAlix
    3,254
    2,657
  36. DJAlix
    3,254
    2,657
    Will add this to the ever growing list of works. Please don't expect an answer in just a few days tho as its gonna take a while to figure out :(
  37. audia38l1
    27
  38. Matthew99
    Matthew99 New Member
    hey there,
    I've been using OBDELEVEN i guess you can call it an alternative to VCDS. For previous mods it's been great. (I'm am definitely investing in VCDS after this)
    i attempted this TPMS on my 2013 AUDI 8VA and done everything successfully up until 'Module 03 ABS/ Brakes. On this OBDELEVEN app there seems to be no way to change the coding part. i was sitting down for an hour trying to change and decided to reset the mmi and try my luck. The TPMS appeared in the mmi but i couldn't click it. also warning lights popped up and i was able the clear 4/5 of them.
    Also i have noticed just like someone else in the forum that i also don't have byte 30. i have inserted pictures to show what I'm talking about.
    any input would be great and well appreciated.
    IMG_5901.JPG IMG_5903.JPG IMG_5904.JPG IMG_5907.JPG IMG_5908.JPG IMG_5909.JPG
  39. shazad manzoor
    25
    Give Alex from Vag Car Coding a ring he's on here and on lin, he'll help you out.
  40. Matthew99
    thanks
