Enabling TPMS for A3 S3 8V *Experimental*
veeeight Apr 30, 2014
  1. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,764
    Caveat - Work in Progress - *Experimental ONLY*
    Proceed at your own risk.
    But feel free to try this out on yours, and post your results in this thread!
    As there is not much info about how to code TPMS onto a A3 S3 8V, I spent about 3 hours yesterday sitting in the car with the laptop.
    After some initial help from Ross-Tech support, they provided me with a Long Code to replace my long code in the ABS module, to see if this would activate TPMS.
    Top line is the original Long Code from the factory
    Bottom line is what Ross-Tech suggested I try
    This seemed to work, and briefly lit the "flat tyre with !" symbol in the instrument pack. So I assume TPMS is enabled in the ABS module. It also illuminated when you ignition on, and then extinguishes.
    However - I still had to find our how to enable the functions (storing pressure etc.) in the MMI, and maybe code the DIS. So I had a poke around......
    I ensured all the following adaptations were set to "active" or already "active" in the 5F module:
    And also Byte 4 Bit 0 in 17 Instruments was ticked
    This then gave the TMPS menu in the MMI
    Next steps:
    1. Figuring out which Bytes and Bits tick box do you have to tick, to get TPMS enabled in the 03 ABS module? (instead of copying and pasting a long code)
    2. Do u actually need to enable Byte 4 Bit 0 on the 17 Instruments module? I'm guessing there might be a message in the DIS when the TPMS alarms, but I don't know. - Anyone with factory fitted TPMS help here? Have you had a warning message in the DIS?
    3. Haven't yet figured out which measuring blocks show that the module is learning values.
    4. Haven't tried deflating a tyre and driving yet to test if the system actually works (still learning values) - anyone want to try this?
    Progress !!
  2. snowfree52
    snowfree52 Full LED baby !
    522
    125
    43
    I have TMPS, will try to see if byte 4 bit 0 is checked when I got time
    veeeight likes this.
  3. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,690
    528
    I have factory fitted TPMS, and (ironically) on the way to its first service a few weeks ago it flagged an under inflated rear-right tyre. There is a loud audible beep, accompanied with the TMPS warning light in the cluster, and a message in the DIS telling you which tyre has the problem. So yes, it is indicated in the DIS.
  4. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,603
    1,189
    Yes, when I've had it go off it has put a message in the DIS. Both times I've had a tyre go flat though, I've noticed it myself before the TPMS has (assume it measures small differences over time better than immediate pressure loss!). It didn't tell me which tyre, but just told me to check pressures. It went off after driving with the space saver on it both times I've used it, and one other time (when the pressures were running a bit low).
    I'm not entirely sure whether I trust it or what it's doing yet, but it looks like you are making good progress enabling it!
  5. veeeight
    6,849
    4,764
    I've also found that it doesn't detect gradual pressure loss (eg: through natural diffusion) of all 4 tyres !
    This was on my 8P.
  6. amped2
    amped2 Active Member quattro Audi A3 Audi Cabriolet Owner Group TDi
    220
    122
    43
    Hi Veeeight, nice write up,have you had any further luck with the last 3 steps you mentioned.
    Rich
  7. veeeight
    6,849
    4,764
    Bit busy with work at the mo, so haven't had a chance yet.
    Pretty confident all will be possible soon!
  8. davidbir
    davidbir New Member
    29
    Brilliant post, did the security code for ABS get worked out? Can you post details?
    Many thanks
  9. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    957
    394
    I have factory TPMS and yes, Byte 4 bit 0 is ticked/enabled.
    John.
  10. veeeight
    6,849
    4,764
    Thanks John, much appreciated.
  11. davidbir
    davidbir New Member
    29
    For info
    The codes which Ross Tech changed relate to the following:
    38 - 3 already ticked - 4,5 ticked
    86 - 7 already ticked - 1,2 ticked
    I just need the ABS security code to try on mine
  12. davidbir
    davidbir New Member
    29
    John, do you have your ABS Long code available for us to check against veeeights?
  13. JohnM100
    957
    394
    Will try to check tonight but mine is not an S3 and is FWD so expect there to be other differences in the long code .....
    Still want it?
    John.
  14. davidbir
    davidbir New Member
    29
    Yes please, Mine is FWD and not an S3 so this may help to work out which codes do what
    David
  15. veeeight
    6,849
    4,764
    Once you get this code from John, and verified the changes,
    you should be able to just paste in your new long code - without needing the ABS security code.
    Fingers crossed.
  16. JohnM100
    957
    394
    PM sent to you both.
    Good luck!
    John.
  17. lukappaseidue
    lukappaseidue New Member
    27
    news?
  18. veeeight
    6,849
    4,764
    In Long Coding Helper:
    This refers to
    Byte 27 Bit 3,4,5 ticked
    Byte 28 Bit 1,2,7 ticked
  19. veeeight
    6,849
    4,764
    At the moment I do not have enough examples of long codes from the ABS module to be able to confidently say what you must change in order to enable TPMS.
    If you want to help this cause further, please either send me your ABS long code via PM, or copy and paste it here in this thread. Don't need your VIN or any other info, just say whether you have or don't have factory TPMS installed.
  20. davidbir
    davidbir New Member
    29
    My long code was very similar to yours veeeight so changing 08 to 38 and 06 to 86 worked for me.
    With John's code I can see that on byte 27: 3, 4, 5, 6 are ticked and on Byte 28: 0, 2, 7 are ticked
    Does this help to unravel the mystery?
  21. davidbir
    davidbir New Member
    29
    The next stage is to emulate a TPMS issue so the light will come on and the information message displayed
  22. veeeight
    6,849
    4,764
    I'm a bit concerned that John's code has 78 and 85. I would like to know why ours is 3, and John's is 7 !!
  23. davidbir
    davidbir New Member
    29
    Without knowing what each bit means for Byte 27 and 28 it is difficult to say. Worth having some more codes and possibly the Exact model/options chosen included with the code as there will be differences because of the options chosen on the vehicle.
  24. JohnM100
    957
    394
    I have 18" wheels, S-Tronic and Hold Assist too. Those are the only other things I can think of that would affect this, unless it's something to do with where the pressures are stored?
  25. veeeight
    6,849
    4,764
    It could be Hold Assist, but until I have more ABS Long Codes to compare, I'm not confident to say definitively!
  26. FrankyShiu
    FrankyShiu New Member
    Good to know TMPS in S3 8V in progress ..........well done ....
  27. FrankyShiu
    any updates ? buddy....
  28. veeeight
    6,849
    4,764
    Mini Update: Testing Successful
    Tonight, I let the front tyre down by 5psi, and drove home from work.
    Within 5 miles, I had a message in the DIS, and the TPMS symbol illuminatetd in the instrument pack:
    So the system works :)
    As only 1 person has sent me their long coding from their ABS module (thank you), I'm unable to help any further without additional data.
    LuisM and JohnM100 like this.
  29. FrankyShiu
    Just asked my friend to get me VCDS cable soon, but actually where the abs long code is???
    I am not familiar on VCDS......
  30. JohnM100
    957
    394
    Excellent result Veeeight. Congrats.
    John.
  31. snowfree52
    522
    125
    43
    here you go mate :
    10F162A234260A74037E070441C72908462C50C0E08294F5F86150F88508
  32. davidbir
    davidbir New Member
    29
    Good news, once we have collected about 10ish long codes with a brief spec and whether TPMS is factory fitted we can give a rundown of exact vcds settings for 8v tpms
  33. davidbir
    davidbir New Member
    29
    Hi there, what options do you have? Do you have TPMS as standard?
  34. snowfree52
    522
    125
    43
    Yes I have tmps. apart from that almost everything is in my sign
  35. FrankyShiu
    "32F193A254202A710178070841C8694CC92A5480E08296F6004100880608" [S38V , without TPMS]
    Thank
    Franky
  36. lewart_waw
    lewart_waw New Member
    10
    Hi, I tried to encode as it is written above, but for me does not work is the MMI, TMPS shine the light on for DIS.
    New codes:
    Byte 27 - 38
    Byte 28 - 85 (Bit- 0 not Hold Bit- 1 instal Hold )
    and 17 instruments - Byte 4 bit 0
  37. veeeight
    6,849
    4,764
    What spec is your car?
    A3 or S3
    Basic SD Nav or Tech Pack ?
    Etc.
  38. lewart_waw
    10
    My car is S3 2013 MY 2014 And Basic SD nav, auto hold, s-tronic,
  39. lewart_waw
    10
    whether you need something to encode nav?
  40. veeeight
    6,849
    4,764
    I have never seen a car with TPMS and Basic SD Nav, so I don't know if the reset menu is in the MMI or not. Or how you reset the TPMS.
    My photos of the 5F module and menus are for Tech Pack.
