Enable rear DRL on MY10 S3
JohnS3 Oct 26, 2010
  1. JohnS3
    JohnS3 Active Member
    3,032
    Does anyone have a MY10 S3 or later with rear DRLs enabled? If so can you please post your long coding from your central electronics unit? Byte 18 contains the headlight info, I know a MY10 TT can have rear DRLs enabled by changing the UK default of hex 58 to hex 59.
    This is my current coding hex 2B
    This was a simple change on older cars, you just switched from north American DRLs (front only) to Scandinavian DRLs (front & rear) with VCDS.
    If any of the Ross Tech gurus are reading this perhaps you may know how to code this feature.
    Thanks in advance.
  2. dunk
    dunk Member
    770
    ;-) in case anyone else needs this answering - its 2C
  3. NHN
    29,328
    1,708
    John can you post up/email to me some screen dumps of the CE pages please, so I can see what the headlight stalk coding page looks like, as I was briefly advised there is a setting within the CE to tell it which stalk is fitted.
  4. JohnS3
    3,032
    Didn't know you were on here too! I'll try this tonight as per the other thread on vagoc.
  5. JohnS3
    3,032
    I can do that tonight Nige. All the long coding stuff?
  6. JohnS3
    3,032
    It is indeed, code changed and working a treat!
  7. JohnS3
    3,032
    Byte 29, bit 6, "Momentary switch for high beam" Now you should be in business!!
  8. JohnS3
    3,032
    I'll email you the screen grabs...
  9. Vertigo1
    Vertigo1 Well-Known Member
    3,385
    545
    Just had a look at this on my MY11 A3 with Xenons & LED DRLs and byte 18 is showing as 25. The helper shows this as being for an 8P1 !?!??! Anyone have any ideas?
