EMS warning - 2001 A3 1.8T in Barnsley, South Yorkshire
Antony 171008 Oct 15, 2012
  1. Antony 171008
    Antony 171008 New Member
    9
    Since buying the car in 2008, no faults until earlier last week where, on braking a touch harder than normal the ESP/ASR lamp lit up now and again ('tho disappeared on turning the engine off then back on). This continued for a couple of days until late last Friday night where, on starting up, the amber Engine Management System lamp remained on. I subsequently drove the 10 miles back home, during which the engine performed absolutely fine with no problems (the EMS lamp still lit). Subsequently, I'd appreciate if there's anyone in Barnsley/South Yorkshire with Genuine VCDS/VAG-COM that could help out. If not, it'll have to be a call to the main dealer this week ...
    Many thanks in advance.
    PS - tokens of appreciation will happily be offered, given the main dealer would be lightening my wallet anyways.
  2. hades-
    9,481
    646
    sheffield anygood for you ?
  3. Antony 171008
    9
    Can do (provided car continues to drive OK...) - when's convenient?
  4. NHN
    29,328
    1,708
    Please utilise the VCDS Owners map before posting new threads, you wont go wrong with Bez :)
  5. hades-
    9,481
    646
    Wednesday,17,October,2012,18:07:44:27402
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    VIN: WAUZZZ8LX2A023151
    Address 01: Engine Labels: 06A-906-032-AUM.lbl
    Part No: 06A 906 032 HJ
    Component: 1.8L R4/5VT 0002
    Coding: 11500
    Shop #: WSC 06435
    VCID: 6DDA235F27FAF470FA3
    WAUZZZ8LX2A023151 AUZ5Z0A7090067
    3 Faults Found:
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-10 - - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62)
    P0118 - 35-10 - Signal too High - Intermittent
    16955 - Brake Switch (F)
    P0571 - 35-10 - Implausible Signal - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 E
    Component: ESP FRONT MK60 0104
    Coding: 0019970
    Shop #: WSC 06435 000 00000
    VCID: 2C5CEE5B8C603D78ADD
    2 Faults Found:
    01435 - Brake Pressure Sensor 1 (G201)
    008 - Implausible Signal - Intermittent
    00526 - Brake Light Switch-F
    im thinking CTS and brake light switch
    any thoughts
  6. Antony 171008
    9
    Replaced CTS - temp' guage when running now shows the obligatory 90°C instead of the 60°C of the previous few weeks. Also replaced the brake light switch - sure enough the original one had failed (had had some kind of fluid leak).
    Spot on bez101 - many thanks once again. Couldn't have gotten better help - as NHN said 'you wont go wrong with Bez [​IMG]'
  7. hades-
    9,481
    646
    nice 1
    glad its sorted
