EML Warning Light and Fault Codes
dk1234 Oct 4, 2013
  1. dk1234
    dk1234 Member
    195
    After taking my car for a service I was advised of the following from them.
    Warning lamps - eml on - 3 faults stored, ecm disabled, coolant fan blocked,
    egr valve electric fault. For them to just do the diagnosis was £138 I figured that the diagnosis might be just them giving me a print out of the fault codes from the VCDS so I declined. I arranged to meet a kind forum member SAiLO who did a scan for me. I've changed a few things without clearing codes in the past so I think the 1st scan included things that wern't cleared before.
    This is the light that is on. I think it's the EML light? What does MIL stand for? does it represent the same light as the picture below?
    The DTC's / faults were cleared and the warning light went off for about 2 hours before poping back on again. I had a second reading done today and the results are below. I would appreciate any help or advice on how I can get them cleared. The bolded ones seem to be more concerning to me.
    VCDS Version: Release 12.12.0 (x64)
    Friday,04,October,2013,14:55:14:26151
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56
    VIN: WAUZZZ8PX5A031138 Mileage: 139310km/86563miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010 -----(*Just a note, on the 1st scan a few days ago this didn't show up*)
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010 -----(*I think this is because I ain't got a CD changer installed*)
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010 -----(*My sound system seems to work ok, radio, cdplayer, mp3*)
    Address 01: Engine Labels: None
    Part No SW: 06F 906 056 CE HW: Hardware No
    Component: MED9.5.10 00 7000
    Revision: 00000000 Serial number: AUX7Z0D7FN60CW
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    VCID: 6ED3223F79F1226E76F-803B
    Subsystem 1 - Part No: 06F 907 807 D
    Component: NOX 0408060030 006 4109
    06F907807D NOX 0408060030 006 4109
    1 Fault Found:
    17808 - EGR Valve (N18)
    P1400 - 002 - Electrical Malfunction - MIL ON
    Readiness: 0010 0101
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0021126
    VCID: 3A7BDE6F7539BECE9A7-806F
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 G HW: 8P0 820 043 G
    Component: KlimavollautomatH12 0150
    Revision: 005265 Serial number: 8P0820043G
    Shop #: WSC 00000 000 00000
    VCID: 306FFC47A345749E243-8065
    1 Fault Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 139274 km
    Time Indication: 0
    Date: 2013.10.01
    Time: 20:44:25
    Freeze Frame:
    Voltage: 12.00 V
    Temperature: 21.5°C
    (no units): 28.0
    (no units): 31.0
    Temperature: 19.0°C
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
    Component: Bordnetz-SG 1.0 H30 0701
    Revision: 00030000 Serial number: 00000000748103
    Coding: 018CCF00A0141000000000000000000000
    VCID: 3E73D27F691192EEA6F-806B
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 00000
    2 Faults Found:
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    004 - No Signal/Communication - Intermittent
    00466 - Control Module for Steering Column Electronics (J527)
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0011602
    VCID: 4385A38B02F3FF06C91-8016
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 012 0030
    Coding: 0000012
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 M HW: 8P0 920 980 M
    Component: KOMBIINSTR. VDO H71 0210
    Revision: D03 Serial number: 2247DD03001449
    Coding: 0004408
    Shop #: WSC 56434 000 1048576
    VCID: 4189A98318EFED16DBD-8014
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 25001048030225
    Coding: 3D0F034A070101
    VCID: 285F14279B953C5EFC3-807D
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D03 Serial number: AUX7Z0D7FN60CW
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 HW: 8P0 035 192
    Component: RNS-E HIGH EU H56 0650
    Revision: 08S Serial number: AUZBZ7E0304060
    Coding: 0225113
    Shop #: WSC 00262 210 58386
    VCID: ECD7A837CFED507ED8B-80B9
    1 Fault Found:
    00857 - CD Changer Unit (R41)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 28
    Mileage: 139267 km
    Time Indication: 0
    Date: 2013.10.01
    Time: 19:50:20
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000048
    VCID: 3D71D573641789F6BF5-8068
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.9 1301
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 008000186D288505489AC63000
    VCID: F9F98163B0BFF5D653D-80AC
    Subsystem 1 - Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Subsystem 2 - Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH25 0160
    Revision: 00003 Serial number: 10000001162547
    VCID: F0EFBC47E3C5B49EE43-80A5
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 E
    Coding: 0000048
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0225113
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 28
    Mileage: 139267 km
    Time Indication: 0
    Date: 2013.10.01
    Time: 19:50:20
    End ---------------------------------------------------------------------
  2. dk1234
    dk1234 Member
    195
    bump, can anybody help me please.
    Mainly with these ones, looking up the codes on Ross-Tech wiki they both don't come up.
    Coding: 0000072
    1 Fault Found:
    Coding: 00062736
    Shop #: WSC 00000
    2 Faults Found:
  3. dk1234
    dk1234 Member
    195
    I have the same code coming up after a recent scan. I did the scan as the eml light popped up and I've noticed that my car sounds a little louder than usual when driving on the dual carriage way. Does anybody know what the problem code could mean?
    P1400 - 002 - Electrical Malfunction - Intermittent - MIL ON
    Readiness: 0010 0001
  4. dk1234
    dk1234 Member
    195
    Anybody?
  5. Sayam
    Sayam Well-Known Member VCDS Map User
    2,703
    631
    dk1234 likes this.
