Emisson control light on. DIAGNOSTIC RESULTS ADDED (from breakdown people)
quattro25years Apr 19, 2013
  1. quattro25years
    quattro25years Member
    I have just noticed that my emissions control light has come on.
    This is whats happening.
    with the engine running it sounds like there is a throbbing noise coming from the exhaust.
    also from the engine there is a ticking noise that sounds like chattering relays (quite loud).
    i took the plastic engine cover off and some thing is moving while the "chattering is happening), not sure what it is , can post a pic of what is moving if needed.
    After turning the engine off I could still hear the ticking noise for a few seconds.
    Any help would be much appreciated.
    many thanks
  2. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,133
    9,138
    Pictures would be good, also which model and year as well please. Thanks. :) x
  3. quattro25years
    Hi Sandra
    getting a bit dark to take pics now. Will take pics tomorrow.
    model is 3.0 tdi s-line on a 56 plate.
    thank you for responding.
  4. quattro25years
    Hi again,
    only earlier today I was thinking of buying a Ross tech cable!(posted this earlier today)
    And only this evening the engine management light has come on
  5. Sandra
    26,133
    9,138
    Thats really bad luck that this has happened. When you post pics, one of the guys will be able to advise you. If you decide to buy a vcds cable user and site sponsor NHN sells the genuine ross tech vcds cable. :) x
  6. quattro25years
    Hi thanks for that,
    i can see the part that is making the noise, its at the top of the engine bay on the right hand side.
    will post pic tomorrow.
  7. quattro25years
    ******** UPDATE ******
    made a mistake , it is not the engine management light ,
    just looked in my q7 manual on page 16 , the light that has come up is the "EMISSION CONTROL SYSTEM" light.
    sorry for the confusion.
    ....I have driven the car with the light on,no loss of power,
    help still needed though.
  8. quattro25years
    Hi
    Update
    Noticed this morning the TICKING NOISE happens when the ignition is turned on, but without the engine running.
    when the engine is running, I can see what looks like a lever moving, this "lever " is behind the component that says "made in USA" .
    i have uploaded a video to you tube with the ignition turned on , but engine not running.
    here is the link
    YouTube
    Will post video of engine running later this morning.
    Many thanks
  9. quattro25years
    Hi
    earlier today called breakdown recovery .
    they plugged into the socket under sterring wheel, and the following error codes came up.
    04203 INTAKE AIR TEMPRATURE CIRCUIT
    05504 INTAKE MANIFOLD RUNNER POSITION SENSOR - SWITCH CIRCUIT HIGH BANK 1
    any help would be appreciated on above
    DOES THIS MEAN I HAVE TO HAVE THE INLET MANIFOLD REPLACED ?
    i have booked my car in with Poole Audi main dealer this tuesday
  10. quattro25years
    Problem solved.
    had to have the throttle body replaced...replaced under warranty .
  11. The911SC
    The911SC Active Member
    1,032
    Yes it does - there is a known issue with the manifold runners on the 3.0 tdi engine where the linkages breaks and stops working.
  12. gupsterg
    gupsterg Active Member
    348
    There is a repair kit for swirl flap links now ...
    Item 1 in kit is the swirl flap link arm, item 2 swirl flap follower, item 3 locking clip ...
    Repair kit P/N 059 198 212 , same P/N for 19 different VAG's with V6 ...
    Red arrow highlight item 2 location and item 3 clip...
    Here is a video showing effect of wear on swirl flap follower/link arm ...
    Wear can also happen on the bearings for swirl flaps as well ...
    There is a TPI / TSB relating to this repair kit ...
    [TABLE="class: cms_table, width: 100%"]
    [TR]
    [TD] Technical product information[/TD]
    [TD] Transaction No.: 2016504/19[/TD]
    [/TR]
    [TR]
    [TD] Engine warning light on, intake manifold flap function - V6 2.7 l, 3.0 l TDI[/TD]
    [TD] Release date: 28-Feb-2012[/TD]
    [/TR]
    [/TABLE]
  13. quattro25years
    Although my problem has been solved -thanks gupsterg for more info
    gupsterg likes this.
  14. gupsterg
    348
    No worries :) ...
