emissions light on - PLEASE HELP
gizmo666 Mar 15, 2011
  1. gizmo666
    gizmo666 New Member
    The emmisons light came on the car a while ago the car is a 2005 audi a3 2.0tdi. looking through the internet most forums said that it was a common fault with the dash light on this year and model so didnt really worry to much.
    The car went to the garage for the cam belt change, whilst there i asked the garage to put it on the machine. It came up with the following faults
    19557 swirl flap motor, open circuit to ground
    19558 swirl flap, no signal
    Could someone please translate what this means! and will it be costly to rectify?
  2. gizmo666
    gizmo666 New Member
    sorry there is another code i forgot
    17056,17057,17058 1,3 & 4 glow plugs circuit
    thanx in advance
  3. Batt284
    Batt284 Member
    98
  4. mike foster
    3,967
    19558 is the Intake manifold flap motor (V157) misbehaving !
    Glow plug problems are cylinders 2 (not 1),3 &4 no warm up period
    Check the symptoms on this website and also the possible cures :-
    Category:Fault Codes - Ross-Tech Wiki
    Just look for the codes you have posted ( 19557 doesn't appear )
  5. hades-
    9,481
    646
    as above but who ever told u
    "it was a common fault with the dash light on this year and model so didnt really worry to much"
    chats ****
