Emissions Light on. Exhaust temp sensor fault?? Help Needed VCDS results Attached.
skiwil Dec 12, 2013
  1. skiwil
    skiwil New Member
    Hi AllSome help needed please.56plate 2.0TDI 170 SlineYesterday I have had the emissions light come on my dashboard.I have given it a good hour and half motorway run today hoping it might be a DPF issue and it would clear. The error hasn't cleared, so I borrowed a friends VCDS and ran a scan today.The results are below. It shows two issues, I was just wondering if one of them could be causing the emissions light (pretty sure its the exhaust sensor). Does anyone know what sort of cost its going to be to fix these faults or is their something else amiss? I cleared the faults but the emissions light stays on and shows the exhaust sensor fault again when scanned.Thanks in advance for your help
  2. NHN
    29,352
    1,720
    Your friends using a fake illegal cable.
  3. skiwil
    skiwil New Member
    00-Steering Angle Sensor -- Status: OK 000001-Engine -- Status: Malfunction 001002-Auto Trans -- Status: OK 000003-ABS Brakes -- Status: OK 000008-Auto HVAC -- Status: Malfunction 001009-Cent. Elect. -- Status: OK 000015-Airbags -- Status: OK 000016-Steering wheel -- Status: OK 000017-Instruments -- Status: OK 000019-CAN Gateway -- Status: OK 000025-Immobilizer -- Status: OK 000033-Flux Capacitor -- Status: Malfunction 001037-Navigation -- Status: OK 000042-Door Elect, Driver -- Status: OK 000044-Steering Assist -- Status: OK 000046-Central Conv. -- Status: OK 000052-Door Elect, Pass. -- Status: OK 000055-Xenon Range -- Status: OK 000056-Radio -- Status: OK 000062-Door, Rear Left -- Status: OK 000072-Door, Rear Right -- Status: OK 000076-Park Assist -- Status: OK 000077-Telephone -- Status: OK 00007D-Aux. Heat -- Status: Malfunction 0010 -------------------------------------------------------------------------------Address 01: Engine Labels: 03G-906-018-BMN.clb Part No SW: 03G 906 018 DN HW: 03G 906 018 DN Component: R4 2.0l PPD1.2 G 4350 Revision: --H32--- Serial number: AUX7Z0F8FNM0IA Coding: 0000078 Shop #: WSC 01089 210 97503 VCID: 74E71A2D175C86CC4D9DE02 Faults Found:000801 - Engine Speed Sensor (G28) P0321 -- 006 -- Implausible Signal - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 12 Mileage: 113328 km Time Indication: 0 Date: 2013.12.04 Time: 09:21:18 Freeze Frame: RPM: 192 /min Torque: 0.0 Nm Speed: 0.0 km/h Time: 0.01 s Angle: 0.0 ° Bin. Bits: 00000000 Bin. Bits: 00000001001140 - Exhaust Pressure Sensor 1 (G450) P0474 -- 006 -- Intermittent - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 1 Fault Frequency: 157 Reset counter: 40 Mileage: 114330 km Time Indication: 0 Date: 2013.12.11 Time: 13:46:40 Freeze Frame: RPM: 1888 /min Torque: 184.0 Nm Speed: 0.0 km/h Voltage: 12.09 V Mileage: 300 km Text: 104 C Pressure: 1022.4 mbarReadiness: N/A
  4. skiwil
    skiwil New Member
    ok, thank you, I didn't know that. Could these readings then be wrong?
  5. autolatry
    autolatry Active Member
    347
    67
    Your flux capacitor is malfunctioning!!
    I wouldn't plug dodgy cables into your car if I were you.
