emission control system warning light flashing............
tisinthepark Feb 10, 2011
  1. tisinthepark
    tisinthepark New Member
    hi there i have a 1.8t quattro sport, i was at traffic lights ready to on green when i tried to pull away the car was very very sluggish it felt like there was a blockage thats when i noticed the warning light flashing????the car has sat idle for over a week and is in need of a service my journey tonight was only 4 miles to the vets with no probs and 4 miles back and it was as i was pulling out of the carpark when the light came on................it also sounds like the exhaust is blowing?????
    thanx for any help guys.....
  2. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    missfire ?
  3. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Ooo That don't sound good have you got AA cover as they will scan the car once you report it.
  4. tisinthepark
    no aa cover............
  5. hades-
    9,480
    646
    prob coil pack
  6. tisinthepark
    can i change this myself?do i have to go to audi to buy the new pack?
  7. hades-
    9,480
    646
    if it is a pack you can change yourself easy
    but you realy need to get the fault codes read 1st
  8. tisinthepark
    so i need to take it to audi then...........how much are the packs roughly......
  9. tisinthepark
    cars going in to a local garage for a test on monday night so ive got my fingers crossed that i will be asking how to change the packs soon after......
  10. tisinthepark
  11. hades-
    9,480
    646
    get oem packs i always change all for and use olds ones for spares
  12. tisinthepark
    yeh its oem ones on ebay and there £100 for the 1.8t ones is this a fair price?
  13. hades-
    9,480
    646
    no it says oem quality
  14. tisinthepark
    ah so it does..............wheres best to find these then bez?
  15. hades-
    9,480
    646
    i only use audi or TPS
  16. tisinthepark
    you must have more money than me........lol
    thanx bez
  17. dsmclark40v
    dsmclark40v Member
    744
    Try having to buy 8 of them! chances are if ones failed then the others aren't far behind. Also might be worth seeing when your spark plugs were last changed and put new ones in at the same time. I only use audi or tps as well
  18. Tooks
    Tooks Active Member
    753
    29
    GSF do a BERU 'Made in Germany' coil pack which they say is similar to OEM quality.
    They're approx £27 each, I've been running four of these in my car for 6 months with no issues after my cylinder 1 coil pack went. I've kept the old three for spares and always keep one in the boot just in case!
    Very easy to change, just need to be careful not to break the plug from the loom when removing it.
  19. tisinthepark
    i got one from audi today(they only had 1 in stock)£36...............the car is running great but the emission light is no longer flashing its on all the time now?????
  20. hades-
    9,480
    646
    TPS trade parts all oem parts
  21. kite
    kite Member VCDS Map User
    676
    TPS= Trade Part Specialists...
  22. tisinthepark
    if i get this light sorted out i will get it fully serviced too so that should take care of the plugs..............should i change all coils?should i stop driving it until i get this sorted?even though its going great
  23. mewstar
    mewstar Member
    64
    i got one today from VW. £34.90.
    fitted it and my light too is still on. if it was a dodgy coil pack causing the emission light to come on, should it reset itself now, or will it need vagcom??
  24. dsmclark40v
    dsmclark40v Member
    744
    You need to clear the fault code in vagcom and it will get rid of the check engine light
  25. tisinthepark
    how do i do this?does it need to go back on the diagnostics machine?
    thanx again for the help lads....
  26. kite
    676
    Trya battery disconnet for 10mins...have your radio code ready
  27. quattrojames
    14,050
    571
    Radio code should store for (I think) two hours.
  28. tisinthepark
    ok i will give this a go in the morning......cheers
  29. tisinthepark
    worked a treat...............thanx lads
