Emergency brake flash Audi A6 Avant 4F C6 coding / adaptation help please...
gupsterg Feb 23, 2013
  1. gupsterg
    gupsterg Active Member
    348
    61
    Hi guys...
    I have an Audi A6 Avant 2005...
    Module 46
    Channel 50 coded to 0 = No hazard flash or brake flash
    Channel 50 coded to 1 = Only hazard flash... No brake flash
    Channel 50 coded to 2 = No hazard flash or brake flash
    Channel 50 coded to 3 = No hazard flash or brake flash
    Here is adaptation/info on my module 46...
    I've been referencing Link:- Audi A6 (4F) Comfort System - Ross-Tech Wiki
    The helper balloon suggests only a saloon car support (+2)...
    Does anyone know/have coded brake flash on an A6 4F...
    Like this video on an A4...
    TIA
    G
  2. gupsterg
    348
    61
    Anyone try with a saloon? have any info to share?
  3. Gizmo68
    Gizmo68 VCDS owner in Kent VCDS Map User
    88
    Yes, I have coded a 2008 A6 Avant (Le Mans) for emergency brake light flash
    gupsterg likes this.
  4. gupsterg
    348
    61
    Mine has factory fit Xenons/LED rear taillights... is a 2005/55 ...
    i) did the brake flash work like in video for A4?
    ii) what was coding you did?
    iii) what was done on the car you coded to initiate brake flash? I found hazard flash only initiate by going 50 mph+, then do hard braking, just before coming to stand still it would occur...
    iv) did it have non LED tail lights?
    Thanks for info :salute:...
  5. Gizmo68
    88
    He has yet to test the lights out in action, the car has halogens and std (non LED) rear lights.
    Here is the screen shot of the adaptation changes:
    (The car is a March 2008 2.7TDi Le Mans Avant)
  6. gupsterg
    348
    61
    So was it 0 in channel 50 before you made changes?
  7. Gizmo68
    88
    Yes :thumbsup:
  8. gupsterg
    348
    61
    Any chance of getting a confirmation from the modified A6 owner? is owner a forum member?
  9. Gizmo68
    88
    No he isn’t, but I have already asked him to try and get them checked.
  10. christof71
    christof71 Member
    60
    Hi all :-}
    Check ABS ECU for adaptation also .
    Module 46 must recognize emergency braking> information about emergency braking should receive from ABS ECU .
    Without additional information about the braking module 46 can not distinguish normal braking from emergency braking .
    sorry for my english,:-}
  11. gupsterg
    348
    61
    Will do :) ... thanks for pointer :icon_thumright: ...
  12. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    ahh good info, maybe i can turn off my hazard flashing now :)
  13. gupsterg
    348
    61
    Hi,
    Viewed the ABS module nothing staring me in the face :think:... any pointers?
  14. christof71
    christof71 Member
    60
    46 covvenience , chanel 50 ,
    +1
    +2
    = 3 :-} Put value 3 and your hazard lights should work.
  15. gupsterg
    348
    61
    My[​IMG], if you check post 1 I have done that already and it work on my car [​IMG]... what don't work is the brake light/ rear tail light flash like in the video I have placed in post 1 ...
    Video is an Audi A4 (8K) I have an Audi A6 (4F) ... perhaps my car does not support it :sorry:...
    I have a 2005 A6 Avant with factory fit LED tail lights ...
    Any update from yourself Gizmo68 on if the owner has tested brake flashing?
  16. christof71
    christof71 Member
    60
    ask someone who has this function to check the adaptation module 09 [bornetz]
    Maybe you have bornetz that does not support this function and you have to change to a new one
    Check your bornetz number
  17. Audi Toby
    Audi Toby 2016 S3 Saloon
    252
    46
    I didn't think mine worked at first.
    Hazards activate over 35mph+ with LITTLE effort. Just a hard brake.
    The Brake lights will flash over the same speed (35mph) how it measures an "emergency/panic" brake is the time between being on the throttle to being on the brake! So it's an actual panic e.g something runs out into the road.
    So drive at 40mph maintaining a gentle throttle, and then as quick as you can change your foot to the brake and stamp!
    They will flash!
  18. gupsterg
    348
    61
    Thank you for your share on how the brake flash work on an A4 (B8/8K) I will try the method you describe of throttle/braking :D ...
  19. Audi Toby
    252
    46
    No worries I spent weeks trying to get it working (lots of painful stops later) I succeeded!
