Elm 323 vs Vag-com
g60leigh Jun 23, 2008
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Hi guys I have an ebay lead and vag-com free version
    but fancy an upgrade
    through a mate at a garage I can have a legitimate user copy of the latest vag-com under his account but need a genuine lead, does anyone knowe where I can get one for realistic money?
    has anyone tried these elm scan leads on ebay, they are all a bit more expensive, but are they any better?
    cheers
  2. Fraser
    Fraser Member
    584
    original rosstech is the way to go
    gendan are a uk distributor
    some have come up on ebay, i missed out on a full hex-usb+can at 125 the other day. otherwise the full price one is an investment as it pays for itself pretty soon
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,769
    31
    If you buy the genuine lead, I think the most up to date software is free anyway?
  4. g60leigh
    1,674
    207
  5. Broken Byzan
    13,237
    465
    It looks like it will work just fine
  6. Issac Hunt
    1,162
    Its counterfeit for sure. It probably will work with version 704 OK, but wont work with the latest version 805.
  7. g60leigh
    1,674
    207
    why do you think it wont work?
    as ar as I can see all the cheap ones only work up to version 4
  8. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    it should work fine, my dongle is not made by ross-tech and says assembled in uk on it, but works fine with every version of vag-com, and i registered it fine with ross-tech, i beleive it was from a uk company who made them under licence a few years ago
    if im wrong feel free to correct this but as far as i can tell all versions of vag-com are free to download and use (shareware), what you can do with it is down to the cable you have, if you register it you get support from ross-tech, if you buy cable used then you have to pay to register it
    how much did you get it for?
