Electronic handbrake
faisal_16 Mar 28, 2013
  1. faisal_16
    faisal_16 Member
    84
    19
    So I picked my car up this morning and I absolutely love it.
    However, I'm having an issue with the handbrake. When it's applied, from what I've been told and read in the manual, I should be able to drive off as usual and it will release - is that right?
    More often than not, when I try and do this, the handbrake does not release and I have to put my foot on the brake and release the handbrake via the button.
    Can someone please tell me if I'm being thick, and what I should be doing, or if it sounds like there is a fault on the car?
    I will call my dealer in the morning but I really don't want to get stuck on a hill before then!
  2. Peterdona
    Peterdona Member
    55
    I was aware that the handbrake auto release as you pull away but can't confirm as I'm 2 weeks away from picking my vehicle up
  3. Gordo77
    Gordo77 Well-Known Member Team Navarra Audi S3 Manual
    1,192
    2,286
    Hmmm seen this myself... I think it depends if you have your seatbelt on or not...?
  4. faisal_16
    faisal_16 Member
    84
    19
    Hmm, my seatbelt was on at all times. Got stuck at traffic lights a few times faffing with the button!
  5. Gordo77
    1,192
    2,286
    I wonder whether you need to have it in gear...?
  6. hittchy
    hittchy Active Member
    557
    74
    Yes - it should release automatically as long as your seatbelt is on. Try putting your foot on the foot brake first before pulling away. The Passat used to be temperamental to that. Mine releases every time but I may have got into a routine now as the A3 is the third car I've had with one.
  7. faisal_16
    faisal_16 Member
    84
    19
    Mine doesn't release with the car at biting point to the point that you feel the whole car lurching forward
    Strange thing is, it doesn't do it all the time with :S
  8. Gordo77
    1,192
    2,286
    Mine has only ever given the message after starting the car and attempting to drive off, never in traffic or when auto stop/start activates... hmmmm
  9. faisal_16
    faisal_16 Member
    84
    19
    So when your moving off after having the handbrake on, you just drive without touching the button?
  10. deci
    deci Active Member
    307
    123
    43
    x2 When starting from cold I often have to brake and release (sometimes not), but when at traffic or temporarily stopped I have no issue just driving off.
  11. Gordo77
    1,192
    2,286
    Yes, exactly. If I stop in traffic and auto stop/start kills the engine, I apply the parking brake by hand, and when I go to move off, I don't need to touch the button - it releases fine automatically.
  12. hittchy
    557
    74
    Yes.
    In fact, I'm just going to go out for a quick spin to see if I'm doing anything different!
  13. Gordo77
    1,192
    2,286
    Take a wee video! :)
  14. faisal_16
    faisal_16 Member
    84
    19
    Ok great, thanks guys. Useful as ever!
    As suspected, it seems there might be something wrong with mine. Will call my dealer first thing in the morning (not sure if they're even open)
  15. Gordo77
    1,192
    2,286
    Hmmm worth having a quick look in the manual to see what it says about the parking brake? You might be doing something to trigger the need to press the brake, can't think what tho!!
  16. dieseldoug
    dieseldoug Member
    240
    53
    HANDBRAKE OPERATION
    I felt this problem also BUT if you increase the RPM (slightly) as you are pulling away the brake will release all the time. I did not do this at first and the same problems you are seeing at present.
    The system will be looking at you needing to pull away hence the increase in RPM, brake should just release quickly.
    This has never failed since the throttle pedal is activated.
    Hope this helps..
  17. WingoWango
    WingoWango Member
    44
    As above. Just feather the throttle and a touch of the clutch and you will see the park break release. Works absolutely brilliantly! A feature I have never had before and love it.
  18. mjc
    mjc Member
    52
    9
    Agreed, the trick is to give a slight amount of revs when pulling away, releases every time. My other tip, rather than look to the illuminated 'P' on the handbrake button to see if it has released, just keep an eye on the illuminated 'P' in the electronic display between the rev/speedo dials, as soon as you give a slight amount of revs and get to the biting point on the clutch the illuminated 'P' will go out and you're good to go.
  19. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,671
    519
    I've been having this issue too. Sometimes releases when I apply throttle and lift clutch. Other times it refuses to release no matter how much acceleration I give it - to the point where it pulls forward even with the handbrake still engaged. Seatbelt on in all cases.
    I was figuring it has something to do with whether I'm stopped on a hill, but as yet I'm still to figure out the logic behind the auto-release. Handbook is lacking in instructions.
  20. Gordo77
    1,192
    2,286
    But do you get the message on the DIS telling you to apply footbrake before releasing parking brake?
  21. mjcourtney
    1,671
    519
    Nope, no messages on the DIS
  22. Gordo77
    1,192
    2,286
    Hmmm anything to do with whether auto stop/start has activated maybe...?
  23. mjcourtney
    1,671
    519
    Could be. I have some time to play around tomorrow so will try a few scenarios and see if I can figure it out. I don't think its faulty, but it would be useful to know the factors that disable the auto-release
  24. Gordo77
    1,192
    2,286
    Mine has only ever shown the message on the DIS about applying the footbrake after starting the car and attempting to drive off. Every other time it automatically disengages fine. Definitely good to know the conditions that need to be met to release it though!
  25. Zig
    Zig Member
    81
    When I had a test drive I am sure the salesman told me that after starting the engine you had to manually release the handbrake the first time on moving off but that thereafter it automatically released.
  26. WingoWango
    WingoWango Member
    44
    You do not need to manually release after starting the engine. If you're on a bit of an incline it has to have enough throttle and clutch to hold before it will release. The only time It wont auto release for me is when i do not have my seat belt on. Hopefully you manage to figure it out as it works a treat.
  27. faisal_16
    faisal_16 Member
    84
    19
    Exactly the same for me. Hopefully we are doing something wrong! I've got a feeling it might be to do with having auto stop / start switched off but will have another play this morning. Glad I'm not the only one with same problem
  28. mjc
    mjc Member
    52
    9
    I also recall reading in another Audi thread (may of been A4) that to ensure you fully engage the clutch pedal (i.e push as far as the travel will allow when engaging 1st (or reverse) gear when preparing to pull off. Not sure if this will help, but possibly worth testing.
  29. faisal_16
    faisal_16 Member
    84
    19
    So I've done 150 miles today with auto start / stop left on and I've had no issues with the handbrake. Not sure what was going on yesterday but all seems to be well now!
  30. mjcourtney
    1,671
    519
    Seemed to behave itself today. It disengages 1st time after starting the engine. The only time it didn't was when I left the car with the ignition on, and then came back to it. The DIS instructed me to push the foot brake first (understandable!).
    Will keep an eye on it.
  31. Gordo77
    1,192
    2,286
    Maybe because you opened the door...?
  32. Vertigo1
    Vertigo1 Well-Known Member
    3,386
    545
    Mine works fine 99% of the time but, on a few odd occasions it hasn't released when trying to pull away. A second attempt gets it though. Might be that I'm not revving the engine enough so will try experimenting a bit I think.
  33. mjcourtney
    1,671
    519
    Yep, I'm assuming that was the reason in this case.
  34. selar
    selar Member
    161
    22
    I'm trying to figure out the logic behind the seat-belt restriction. I know that you don't want an automatic brake-release kicking in when you're not ready to drive, but I can't imagine a situation where someone has the car at bite point with their feet without being aware enough of what they're doing to cope with the release of the brake. It caught me out a few times moving the car around the driveway when I wouldn't normally put on a seatbelt.
    (P.S. I know you can disengage it manually without your seat belt on.)
