Electronic handbrake not working
motionlee Jun 25, 2011
  1. motionlee
    motionlee Member
    98
    Hello i have a 56 plate a6 with the above being inopertive, when you try to operate the light flash's on the switch and on the dash, vcds comes up with 02443 control head in parking brake, and 00473 control module for elec parking brake (j540) in abs module.
    I know the switch is extremly common in the passat model, but unsure in the a6, with these codes does anyone have an idea or had themselves same codes.
    Also how diffuclt is it to remove the switch ? they are cheap to buy
    thanks
  2. Cockney Boy
    Cockney Boy Member
    483
    I have a spare switch, and it will take about 30 mins to change
  3. Wizza
    Wizza Member
    750
    15
    The worse invention on a car ever!
  4. motionlee
    motionlee Member
    98
    Just to up-date this, i replaced the h/b control module and all is well, had a fault with the air flow flap in the inlet manifold aswell, vw wanted £350 plus, i removed the inlet and repaired the ball,socket/rod for free, just my labour.
    Customer was really pleased as i saved him a fortune
