electrics problems/ wiring diagram needed
moggie93 Jul 13, 2012
  1. moggie93
    moggie93 Member
    96
    Hi there,
    I'm in the middle of fitting a towbar to my b6 avant.I'm trying to work out the connections in the rear lights. I have removed both rear lights so I can get at the plugs to trace the correct wire. When I turn on the side lights my front side lights flash constantly.
    My side lights are led ones and have had no problems with them so far.
    Anyone have any idea what will be causing this?
    Does anyone have a copy of the wiring diagram for the rear lights so I can find the correct wires to connect to.
    Thanks M
  2. benjie
    benjie Well-Known Member
    1,223
    304
    Here we go, I have assumed you have the highline computer installed in your car (you get bulb-out warnings on the dash) as I believe the wiring is slightly different for highline/lowline.
    Wire Colours on diagram -
    [TABLE]
    [TR]
    [TD][/TD]
    [TD="class: color-leg"]sw[/TD]
    [TD="class: color-leg, align: center"]=[/TD]
    [TD="class: color-leg"]black[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="class: color-leg"]ro[/TD]
    [TD="class: color-leg"]red[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="class: color-leg"]br[/TD]
    [TD="class: color-leg"]brown[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="class: color-leg"]gn[/TD]
    [TD="class: color-leg"]green[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="class: color-leg"]bl[/TD]
    [TD="class: color-leg"]blue[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="class: color-leg"]gr[/TD]
    [TD="class: color-leg"]grey[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="class: color-leg"]li[/TD]
    [TD="class: color-leg"]purple[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="class: color-leg"]ge[/TD]
    [TD="class: color-leg"]yellow[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="class: color-leg"]or[/TD]
    [TD="class: color-leg"]orange[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="class: color-leg"]rs[/TD]
    [TD="class: color-leg"]pink[/TD]
    [/TR]
    [/TABLE]
    Hope this helps...
  3. moggie93
    moggie93 Member
    96
    Thanks benjie, is the diagram for a left hand drive? reason im asking is it shows a left hand fog light. No wiring colour for ws.
    Thanks M
  4. moggie93
    moggie93 Member
    96
    All sorted now.. Thanks benjie..
  5. benjie
    1,223
    304
    Sorry, just seen this. Glad it's all sorted. For reference, (if anyone else needs this info) ws was code for white wires and the diagram shows all lights coming from the J519 (onboard power supply unit) to each rear light.
