Electrical Issue with Dashboard brightness and headlight adjuster.
Rider4life Sep 10, 2013
  1. Rider4life
    Rider4life Member
    72
    Both roller type switches on my 2004 a3 don't work. The dash lights are on but dim and the headlight height adjuster does nothing aswell. Where do i start? Would like to test it before buying another set of switches but not sure what wire does what. Could it also be a fuse?
    Any help will be appreciated.
  2. BigMack
    BigMack New Member
    12
    I am also having the same problem.
    Cannot find a blown fuse and have replaced the full switch pack, but to no avail.
    Any help would be greatly appreciated.
    Arron.
  3. Rider4life
    Rider4life Member
    72
    So you replaced the switch and there still not working...Mine's most likely gonna be the same then.
  4. BigMack
    BigMack New Member
    12
    Yeah borrowed a switch from a friends car and it didn't work. Put my switch into her A3 and it worked no problems. Did your two rollers stop working at the same time?
    In my case the headlight roller stopped working a long time before the brightness roller did.
  5. Rider4life
    Rider4life Member
    72
    I bought the car 2 weeks ago and didnt think to check them. Hope its a simple fix.
  6. T8DPR
    T8DPR If Carlsberg Made Audi Drivers...
    801
    143
    43
    I'm also having a similar problem, but basically the dash and console lights don't fail completely, they just fade to the lowest light whenever they want to! If I knock the headlight switch they come back up full and the adjuster works ok again
    any ideas?
  7. NHN
    29,568
    1,779
    Check all wiring & log with vcds.
  8. T8DPR
    801
    143
    43
    Just to bump this thread with something a few people may find useful
    I posted a few days ago about my faulty LED sidelights that were excellent for about a year til a resistor in one of them failed
    I'm ABSOLUTELY certain now that although the bulbs were great for a while, they were DIRECTLY linked to the dashlight issue I mentioned above (post number 6)
    SO anyone else who is currently experiencing fader issues with your dashboard clocks (and stereo button lights as they're on the same link) then quite simply your choice of sidelight bulbs may be the issue
