Electrical Faults Please help!!
kba3t
Please help!!
Boot lock went faulty, when trying to close the boot and lock it manually... now the central locking, electric windows and alarm has stopped working.
I have checked all fuses but no joy!!....i fixed the boot lock (just a spring jumped out of position).
Anybody got any info or had this fault before.... i would appreciate your input...
Kenny
Puzzled 98 A3t driver! /ubbthreads/images/graemlins/noidea.gif
Hi
You could try disconnecting the battery for ten minutes and see if that clears the fault, not sure if you will need the radio code.
Hi,
I was thinking about doing that but i dont have the radio code .... may try that as a last resort.
disconnected the battery for 15 min...still no joy!!!
can anybody else shed any light on this??
your best bet is to try to find somebody locally with vagcom to check for a possible error with the central locking module. All i can suggest is to unplug the tailgate electrical connector and see if it still doesnt work just incase there is something wrong with the latch that caused it to come undone.
my mate has an s3 and the vagcom software, ran the test and no fault showed.
I will check the connector a shot
Does anybody have the electrical schematic diagram that i could check!!!!
