Electric Window Help
Reesy Mar 17, 2011
  1. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Hi,
    My question is about the rear electric windows on my A3. My problem is they open only from the front, which is not ideal. Has anyone else had this,and if so, could they shed some light.
    Thanks in advance
  2. dany2k
    dany2k Member
    318
    hi mate, easy fix: had same problem on a vag group car. window switch can be faulty, even though it looks like there's absolutely nothing wrong with it! cheapish part (£15 at stealers) and very easy to fit.
  3. Reesy
    3,640
    148
    So you think changing the two rear window switches should cure it?
  4. dany2k
    dany2k Member
    318
    should do it mate. a bit strange how it's both of them, but it has happened to me an all so what can i say! if it helps, the front passenger side switch and rear passenger side switch are very likely going to be the same, so switch them around for a tester ;-)
  5. Reesy
    3,640
    148
    Well if I tell you that around the same time both the passenger and drivers side front went as well, I was pretty annoyed!
  6. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    Could be a fault with the button in the drivers side door that disables the rear window buttons.
