electric seat lumbar controls not working
mm707 Mar 15, 2013
  1. mm707
    mm707 Member
    278
    Hi,
    Both seats have electric lumbar switches and neither of them work.
    Any ideas where to start looking to fix this ?
    2007 A4 tdi 1700
  2. hades-
    9,481
    646
    fuse
    or was the seats swapped at some time
  3. NHN
    29,328
    1,708
    +1 if both are dead, then I suspect common point would be fuse, unless they split feeds.
  4. hades-
    9,481
    646
    im sure they have a fuse for each
    when i fitted the S4 seats i had to up to 20 and was 1 for each side.
  5. mm707
    mm707 Member
    278
    No mention of these in the fuses list in the owners book.
    I did hear that they were thermal fuses ???? but I wouldn't know where to start looking for those
  6. hades-
    9,481
    646
    behind the kick panels either size
    im sure mine were 10 and i uped to 20
  7. mm707
    mm707 Member
    278
    Thanks Bez, are the thermal fuses there, I've taken the side panel off the drivers side and they are all blade fuses, none of these are listed for the controls
  8. hades-
    9,481
    646
    its a 10 amp blade fuse red
  9. NHN
    29,328
    1,708
    I looked on elsa & for an existing electric seat car, it says for say an A4 avant 07, thermal fuse S45 for drivers which is a 30amp on a relay plate by central electrics behind dash panel & the passengers is S46 30amp down on the side panel passenger side also on a relay/fuse/connection plate.
    Bez did you car have just electric lumbar before you fitted full electric?
  10. hades-
    9,481
    646
    yes i used a guide from audizine for the 2 fuse locations.
  11. NHN
    29,328
    1,708
    TBH if it was lumbar only before, you shouldn't really just up the fuse as the wiring wasn't installed to cater for the load of full electric seats, lumbar uses less current than say full electric, using multiple direction electrics at same time could end up frying the wiring, if the tolerance wasn't allowed for on the lumbar factory wiring.
