Electric recaro leather seats...? Will they work
shaz Nov 1, 2012
  1. shaz
    shaz Member
    167
    Electric Leather Seats - Will They Work? B6 Avant
    Hi, A friend mine has recaro electric seats fitted to his B6 Avant, He has offered them for sale to me, For my Quattro B6 Avant,
    Now my dilemma is will the seats work in my car? ie the electric seats will they adjust like normal?
    I have heard that my car will have the plug already there and that they just need connecting...
    Feedback appreciated as soon as due to my friend having other potential buyers for the interior... lol
    regards
  2. chasdrury
    chasdrury Member
    360
    17
    If you search on here four rile did a full write up. There is some wiring you'd need to do
  3. shaz
    shaz Member
    167
    Right, I managed to fit one seat it, the plug was same although it had two pins less, plugged them in and the electric seat started working...! But about 10mins later whilst I put the bolts in the seat buttons stopped working?
    Any ideas what's happened? Otherwise il have to call an electriction out
  4. shaz
    shaz Member
    167
    Is there anyone on here who has fitted leather electric seats to an 2004 b6
  5. chasdrury
    chasdrury Member
    360
    17
  6. benjie
    benjie Well-Known Member
    1,223
    304
    It needs a higher amperage fuse doesn't it?
  7. shaz
    shaz Member
    167
    My lumbar support has stopped working on my cloth seats - it were defo working before,
    Iv searched for a fuse for the lumbar support but it cannot be found,
    Any ideas chaps?
    Bear in mind it the electronic seat worked for about 10mins but when I began to bolt it down it stopped working
  8. chasdrury
    chasdrury Member
    360
    17
    Yep. 30amp for full electrics. 10 for the normal seat. Shaz, you will have blown the fuse. Read the link and you'll see which on it is.
  9. shaz
    shaz Member
    167
    Hi mate, sorry if I'm being annoying, iv checked every fuse in the drivers side fuse box and every single one is ok,
    I have read through the link and cannot see where a fuse is Mentuoned,
    Any ideas what number fuse it is or can be?
  10. chasdrury
    chasdrury Member
    360
    17
    'Last, while you're here remove the 10amp red blade fuse that's pictured here beside the 2 silver thermal fuses. replace it with a 30amp. that's the power fuse for your seat movement. 10 amp was Ok for electric lumbar support but not the full functions of a recaro seat.'
    'The fuse for the passenger's side is located behind the kick plate in the passenger's footwell. lever off the long plastic trim that runs from seat to glovebox along the floor, starting at the end nearest the seat.'
    'Under the large part you'll see a few electrical connectors and a lonely little red 10 amp blade fuse. change it for a 30amp and put the plastic trim back again.'
    All from the write up by fourcircle as per previous link
  11. hades-
    9,481
    646
    yep as above simple change the 2 fuses
  12. shaz
    shaz Member
    167
    Chasdrury.... YOUR A LEGEND! And so is fourcircle for that superb write up!
    Seats are all working, although a right pain in the arse to fit,
    Can't wait to show you guys pics of it
  13. NHN
    29,298
    1,701
    Have you checked the wire gauge supports 30amp safely?
  14. SL11CKK
    SL11CKK Active Member
    693
    35
    We are still waiting for the pictures! :drool:
  15. shaz
    shaz Member
    167
    Not sure to be honest, once there complete the position of the seat won't be changing.
    Pics are on the way, unfortunately mine didn't have an armrest fitted and therefore I need to cut a small hole in the top of the tunnel inorder for it to fit,
  16. drift king
    drift king New Member
    Hi guys, I know this is an old thread but have an 2002 audi a4 b6 sport the normal seats with electric lumbar supports. I just wanted to confirm that if i buy fully electric seats, will the wiring be for my electric lumbar support be the same as the fully electric ones and just be a case of plug and play apart from a higher amp fuse? Thanks
  17. hades-
    9,481
    646
    some times it is some times not
    better off pulling a seat and checking first.
  18. drift king
    okay thanks
  19. sabaxter
    sabaxter Active Member
    465
    27
    If not kufatec make the relevant looms to fit fully electric!
  20. passat16v
    passat16v Member
    216
    19
    ive moved the passenger kick plate on my b6 cab and cant see a 10 amp fuse and on the drivers side it looks like 50amp in the brown fuse holder.????
    Is that the one I should be changing
  21. shaz
    shaz Member
    167
    The fuse should be under the steering wheel. I'm pretty sure that was where mine was the one I changed
  22. passat16v
    passat16v Member
    216
    19
    do I change number 1 or 2 :)
  23. shaz
    shaz Member
    167
    I'm pretty sure it's the number 1. Because I remember changing mine to a 20amp fuse.
